Me and a few owners in chennai are facing the No network issue on our bikes for more than a day. Can someone update the ETA of the resolution? @abhishek.balaji @Ather.Team
Try doing a shutdown and restart to see if the issue persists? Also, do raise a request through the app or by calling CS.
Hey Guys. This is Puneeth from Chennai. I have booked the Ather 450 and got a confirmation and payment gateway is open but have many things going on in my mind. Please ather 450 owners ( chennai owners - specially keen to know your view) do let me know your experience post buying the vehicle and how is it till date?? Buying a EV is a big hiccup, do share your experience so that its much easier to go ahead with making a decision.
Go through the above discussion with a filter of Chennai.
Also, check in the below discussion to know more.
also this,
I am using from 12.02.20.i am happy with450. Chennai service team also good. You can buy and enjoy with sports mode
Ather will not disappoint you. In my opinion first book it. Secondly take couple of test ride. Finally if read forum and get info from owner on road.
Lastly if u like it wait for payment window. Or else cancel the your order.
Why donât you type review in the search bar on the forum. Youâll find a lot of long term reviews of the 450.
3 posts were merged into an existing topic: An 'e-motionâal connect - Hemanthâs Ather 450
Hi @abhishek.balaji issue wrt to front suspension or some part hitting something remains the same even after sending the vehicle twice for service. The original thud sound remains no change in sound , looks like service team is not able to get the issue that is described . Can you send someone service engineer so that It can be clearly explained and show the exact issue that I am facing , please send Karthik from service/line assembly team so that he can understand the issue clearly.
Sure, Iâve flagged this to the team, and theyâll reach out to you to send someone experienced from our team to understand this issue.
I took delivery of my Ather-450 yesterday. The three rides so far have been good. I am not sure if its an issueâŚthe Ather App on my mobile is just staying at âloadingâ. It was fine at my home and this issue is at my office. Is it a bad cellular network to which the scooter is hooked on to?
Unlikely, if the app says loading. It usually means thereâs an issue on the server-side or on your network. Is your office using any VPN or proxies? Have you tried it using your cellular network at office or is the issue only on the office WiFi network?
ThanksâŚI am on my cellular network. Anyway, nothing to panic as long as the scooter starts in the evening. Will observe.
I got synced a few minutes back and lost it again. Not sure whats happening. Need to observe.
In the above screenshot, the predicted range is at 65km in ride mode (top of the screen shot) and the projected range is 79km under recent ride. I am a bit unclear about the different ranges mentioned. Request someone to kindly decode this.
To be precise, whatâs the figure I would be getting?
Thanks.
This is the range remaining based on your current battery capacity, for the true range. So for Ride, itâll display out of
Eco - 75km Ride - 65km Sport - 55km
Predicted range is calculated based on your past history of rides. As you ride more in each of the modes, this number will change based on your driving patterns. Itâs an indicator of how your driving style is and how much range you can expect based on the driving style.
The projected range is displayed per ride. Itâs an indicator of how much range you can expect out of a full charge if you ride the same way as per the ride.
For instance, in your latest ride, your project range is 79km in Ride mode. If you drive with a similar riding style as this ride, youâre likely to get 79km out of a single charge in Ride mode. Which means, your driving style is better than the True Range ![]()
Thank you so much for giving clarity. Now need to extend projected range to 100 plus. Too greedy???
Nope, many users have done it. Over the next month, try getting used to the vehicle and your driving styles and try to do both - experience the performance and try to breach the 100km predicted range mark
@Ather.Team @abhishek.balaji yesterday i took delivery since then there is no network in my vehicle , so i am not able to charge the vehicle as it is showing authentication failure. i have raised the issue with CC they are taking time but problem is not resolving. please help in resolving the issue ASAP.
Hopefully yes.
Itâs been only a couple of days and about 120 Kms, Iâve already crossed 81 km on ride, so I guess 100+ shouldnât be too difficult on Eco. Seems plausible.
After the pooja for the vehicle delivered yesterday, I plugged in the charger. Things went well for first three minutes and the unit stopped charging. I could not figure out the reason. I tried pressing reset button and switched off and on the switch. This went on four times, but did not get through. Message âUpdatingâŚâ flashed on the screen and subsequent to that charging went on smoothly for the next two hours. Is it that the charging unit got updated with the latest firmware? is this normal?
