3 posts were merged into an existing topic: Updates and new features
There should be an option to name favourites on the app. Like, a friend’s house, the park, a common meeting spot, etc.
“2nd Cross Road” isn’t really appealing.
Also, this makes it faster to select from a list.
11 posts were split to a new topic: Hazard lights
A post was merged into an existing topic: Open API and Platform
Can we have a option to stop charging at 80% to 90%
Much needed option. I voted for it.
And add an option to auto unlock of charging connector after 80% for the public charging stations, in future? Yes, auto cutoff should be first feature.
I think auto-cutoff through software is a better option. Addition of mechanical mean to unlock connector only makes assembly more complex and prone to failures. Moreover, auto-cutoff at 80% must be a relatively easy option to be provided through an OTA update.
may be a contact owner option in charging screen while on public charging , upon pressing it ,owner should get an alert through app
> , else displaying contact number also fine.
If auto unlock is an option that can be enabled, be great if the user can set a cut off via app or dashboard- eg unlock at 60% charge or range = 35kms. Each user may not need 80% or more every time. For eg, I may be looking to get enough charge to just get home and finish charging there.
mechanical unlock already exists, it is not something new to be added.
Maybe the person can enter his mobile number while pressing the contact owner button, and the owner gets the mobile number and calls back the person. Better yet, the person can input mobile number and Ather customer care or software can initiate a conference call to owner and the caller.
Getting an alert though the app is probably the most non-intrusive and privacy conscious option I feel, as the community grows, passing on personal mobile numbers to everyone is not such a great idea. The app alert option serves the purpose, only catch is network connectivity.
I know they exist, its just that, a software update is easier and fail-safe compared to mechanical parts in long run.
2 posts were split to a new topic: Sentry mode
oh! looks like I didn’t make it clear.
The charger unlock function requires that owner to return put his key and turn it ON before the next user can plug his scooter for charging. I was referring to this being automatic after the cut off. The mechanical cut off is not for charging I was referring to release of charge handle so that next user in the Q can charge their flight.
Doesn’t work when the vehicle is turned off
Oh okay… So you mean to say if the vehicle is turned OFF (not shut down) and getting transported thru another vehicle, we cant track the location thru Ather App… Is that correct?
Correct!!
