Hi folks,
The tips make sense (thank you, @saranyam.13891 ), but I was skeptical about the range (~100km in 450X with Sports and Ride mode with 14% battery left).
I did a test run of my Ather 450X today. I wanted to see the results myself (as there can be factors that other people overlooked but could have affected/helped to achieve the range).
TL;DR: What worked for the author didn’t work for me. I didn’t get the expected range as the author mentioned; instead, I got a decent range more than the projected range. Don’t think the projected/predicted range is always true in real-world. Even when you follow all tips and have a good efficiency track record, you might still end up going up and down the hills, which makes efficiency fall (given that the speed is constant).
Here’s the detailed review of the test run.
Before I begin, please note this is not about the projected/predicted range in the Ather dashboard/mobile app. In this test run, the battery literally went from 100% to 0%.
Bike condition
  • My Ather 450X is lesser than a month old now (around 3.5 weeks).
  • I don’t use my bike daily. The odometer reading was 1044 km before starting the ride.
  • I have not used Ather grid (fast charging). Also, the bike is a month old. So let’s assume that the battery has not been damaged/tire pressure has not decreased.
  • The motor belt looked clean. Had it water washed yesterday.
  • I had 100% charged the bike before the test.
Ride condition
  • I am ~70kg, and there was no pillion rider during the test.
  • The initial and last 16km were on the road with less to moderate traffic (as in I harsh braked just once). The distance in between was on the highway, so no traffic at all. (It’s kind of near-ideal ride condition.)
  • The ride was ~98% on the road. The remaining 2% was kind of off-road due to road repairs.
  • The weather was a bit sunny with winds.
  • No rash driving (as in I am not trying to go 40kmph in 4 secs). The throttle is sensitive comparing it to other ICE scooters. Just a slight throttle (in Sports mode), it smoothly reaches 30-40 kmph in few seconds.
  • I used regen braking as much as possible and avoided harsh braking (but had to harsh brake once).
  • I tried to keep the battery utilization light (in simple terms, avoided red halo around the projected range as much as possible). Talking about the speed (left side), it was light brown to red (when cruising on the highway at 60+ kmph).
  • Bluetooth was off and screen brightness was set to low.
The most awaited test run
I planned to ride ~80kms using Sports mode only (and occasionally Ride mode). If what the author said was true, I should be able to pull the feat successfully as I think I have met all the criteria mentioned by the author and other people in the comments.
I tried to keep the speed around 55-65 kmph. On the highway, I was cruising with 60-65 kmph speed and occasionally hit 75 kmph once (in the first half.)
The battery percent left and the distance covered during the ride are as follows:
Battery % left Distance covered Range in last 20% charge Comments
100% 0 km N/A -
80% 16 km 16 km As expected, due to little traffic.
60% 37 km 21 km Unexpected but nice. Stopped the bike around 59% (38.1km traveled with 28.8 Wh/km on avg) for a small break and started to head back with a 55% charge left.
40% 50 km 13 km While coming back, the wind was opposite. Also, the range in the last 20% charge has dropped. Weird.
20% 61 km 11 km This is when I realized the “unexpected factor” - slopes. The number of times I went uphill is greater than those I did in the first half.
0% 78 km 17 km Around 18%, I changed to Eco mode and kept about 30-40 kmph to reach home. The battery is 0%, and the bike automatically stops. The screen is still on.
Observations
  • Using Sports mode (majorly) and Eco mode in the last 18% charge, I could ride 78 kms successfully. I think the tips helped me (65 km in Sports and rest in Eco), which is more than Ather’s projected range in Sports mode.
  • What worked for the author (~100km range) didn’t work for me.
  • When the battery reaches 15%, Ather automatically disables mode switching. It will be in Eco mode till it reaches 0%.
  • When the battery reaches 5%, there’s an annoying short notification on the dashboard saying to “charge battery” even when driving.
  • When the battery is 0%, Ather doesn’t switch off like a mobile phone :P. It will still show battery percent, speed, etc.
  • If you can travel X kms using a 50% charge (following all tips), never assume that you can travel back with the remaining 50%. (Slopes might kick in. If you are unlucky, winds blow from the opposite direction, or you might detour due to traffic).
Suggestions for people experimenting with their bikes
  • Try this feat yourself. Know your bike. What worked for the author didn’t work for me. What worked for me might not work for you.
  • I drove the bike on the Bangalore-Hosur highway (part of NH44). I am not sure if the altitude is a factor for the range I got. Try Ather at different altitudes if you can.
  • Always have the portable charger with you. Don’t forget!! (like I did).
If you don’t plan to experiment, stick to the projected/predicted range Ather gives you.
Questions that still remain
I have a few questions. If you know the answer, please comment on it.
  1. Are there any factors that I missed/overlooked?
  2. Will draining the battery to 0% damage the battery? Will doing it multiple times damage the battery in the long run?
  3. Even if the battery is 0%, the dashboard is still on. How long can the dashboard go with a 0% charge?
  4. Does the dashboard have a separate battery of its own?
Finally, if you want more details about the ride/have some specific questions on the conditions of the ride, please let me know.
Hope my test results help someone.
Screenshots
First half:
Second half:
Hi iam using ather 450 plus since 3 months in visakhapatnam. I have been getting these wierd squeaky sounds from my vehicle. I contacted ather space in visakhapatnam and they said it is due to rain and the issue will be solved during my first scheduled service. My odo reading is only 1700 km and there still a lot of time for my first service. How do I resolve this problem? Please help
Try cleaning the belt drive
Yes I have tried cleaning it several times but no use.for a few minutes it will be ok but again the same noise😐
Maybe belt adjustment is what is required.
How much kw/h consumption by bike is considered ideal. And how do we try and get the ideal consumption rate? How does it affect the range of EV?
It can go down to 21 kw/h or lower if done good enough…
I had a good breezy day today and took a relaxing ride back from work. So this…
Efficiency & Range is proportional. Some one getting an efficiency of 25 Wh/km will get double the range of some one getting 50 Wh/km.
For Solo: < 25: Great 25-30: Good 30-35: Average
For Pillion: Add 5-10 depending upon the weight of the pillion.
Thank you… to sum it up… RIDE mode is most preferred if riding between 45 -60
I got only 60.8 km range even driving at efficiency of 33.3 wh/km. In this efficiency the projected range is about 85-88km but in real life it’s not even close to that, ather 450 plus have same hardware as 450x that means it also have installed battery pack of 2.9 KW but we plus owner have only access to 2KW which is not justified at the price of 1.7 lakh which ather is getting. They should gove us more access to the battery pack and increase the range rather than locking it so much that it’s affecting the range alot.
Can we spot the location of scooter when shutdown ?if not then difficult to trace when it gets lost
That’s bothersome. How’s the range so low despise a good efficiency?
That’s what I am trying to figure out, My guess is that the battery pack is limited to 2.2KW in 450plus so its 100% is 70-80 percentage of installed battery pack so it’s not charging to its max voltage, second thing is in restricting the capacity the software have some bugs so it’s causing the issue and I am not getting the range which I should get.
The specs on Ather website clearly indicate that 450+ has less usable battery capacity and less true range as well. Also, 450+ cost was less than 1.70 lakhs when it was launched. I don’t think you would have paid 1.70 lakh for your 450+. As far as I remember, 450+ cost was 1.50 lakh when it was launched. I have a 450X Series 1 and I had bought it at 1.70 lakhs in Pune. The policy of limiting features for different prices is common in auto industry. I would understand your concern if you had paid 450X money and got 450+ features.
As for the bugs, yes I agree there are software bugs and they need to be fixed. As far as I know, most of the bugs don’t affect the range as such.
What @thakur.ketan said is correct. I also own 450X Series one and was one of the few customer who bought it very early and it cost me around 1.7 OTR.
And as for the range you are getting, you have usable battery capacity of 2.23KWh or 2230Wh. So if you devide your battery capacity by efficiency of 33.3Wh, you get around 66.9kms of range.
I bought it on May 2021 and yet it costed me 1.7L on road
Yes it cost me around 1.3 lakh but due to subsidy but company is getting full amount approximately 1.7 lakh so they should provide the range justifying that price, it does have battery capacity available in it it’s just they should increase the access bit more so that range can be sufficient considering the price range.
Will brand new bike conditions affect on range? Like normal bikes give less average when they are new, they are not smooth when they are new. (at least for 1st 1000 kms) Is it same with Ather 450x? Will it take few Kms to get smooth and better range?
Yes, however it will not be due to machine but due to throttle input which you will adopt in due course.
Agree. If people are comparing 450x vs + prices, there must be consideration that 450+ owners paid more than 450. Then why range or battery lesser than 450. It can be lesser than 450x but must be higher than 450
