Setting up Your Home Charging Point
I believe around 4.5ft from ground level. I asked for mine to be about foot higher to keep my dogs from playing with it.
I am trying to get approval from my apartment’s management commitee for the charger installation. This being the first ever charging device in the society ( a 250 flats dwelling), they want to talk to ather installation team and I am trying to work with ather offline on this.
In the meantime I have collected questions from them here are the main ones. Can someone here reply them from their home charger installation experience?
  1. How the cable will be drawn to parking,
  2. What kind of wires will be used
  3. What kind of conduit will be used,
  4. Is it going to be single phase or three phase.
  5. How the charger will be placed
The charging team is working in many places in Bengaluru and Chennai to install chargers both. Ather Grid and Home charging Pod (in Bengaluru as of now) Hopefully you should get a call by this weekend… :slightly_smiling_face:
Thanks for the Information :slight_smile: I have called ather team few minutes back they said charger installation will be done this Thursday.
Thanks
One query: I got my charging point installed last week and technician told charging will not happen when the DG is ON and it ll charge only on Main power.
I was fine with that. But, wanted to know how others opted and why?
Same here.
When the generator is on, it will not charge
I am not sure whether its suitable solution.
Can you check if the generator has grounding done may be that should solve the problem.
Because I read it somewhere grounding should be done for generators as well
Generator had grounding but will not support the load…
Hey guys, got my charger installed a few days back. The thing is, it’s green in the mornings and red in the nights. Is this a major problem? Or has it happened to any of you before?
How to measure home pod energy consumption…! Do we have specific smart device can buy online… Will ather team who come for installation do that work for me…!
You can use this or similar ones to find the consumption of the pod .
Thank you… But does this require installation along side home pod?
Its a plug and play device , connect this to the wall socket and then pod to this meter, like this if there is provision already made .!
Thanks a lot… I’ll book this now.
Do you have voltmeter with you? (you may check the line voltage even in BESCOM meter, if it is digital) Guess at night when the line is loaded, voltage falls below acceptable level.
I’m facing that issue.
My charger was red last night. Tried everything but it still glowed red. It’s worked perfectly fine for the last couple months though. Decided to call Ather Support this morning.
This morning, just checked and it was green.
If this is happening everyday, you might have to get Ather Support to have a look at it.
Please share the results after testing if your are planning to get the watt meter .
Sure
