At the road signal, if some one ask me the cost of Ather, how much should I say ?
1.13 (+cost of DOT ) / 1.49 / 1.59 / 99K
Just say, “goththilla”.
Infact, I experience this (people asking this question) even after 5 years of my Vespa-LX125. I am at times really scared to park in slightly desolate stretches. I am sure Ather owners would be scared too.
How can I say " gottilla" when am riding one.
It happened with me 2 - 3 times recently and I couldn’t tell them the cost but I said for how much I bought one.
It depends on how they ask me the question, If it’s only “Yest aythu?” i tell them the price.
If they ask “Yest aguthe?” i tell them “Price change agthairuthe Sir, website check madkolli”
Few people come upto me and say other things which annoys mem. Things like… “Range ilwanthe or tumba costly anthe” i reply “nimugidhu sigolla bidi, model stop agtha idhe swalpa dinadalli”
I have reading posts on the following.
Under what conditions is the rear wheel locking up? Those who experienced this, kindly throw light.
Freezing up of display. Is it a matter of concern that one should not use the bike while in motion. Can the bike still be started when one finds that the screen is frozen right at the start of a day?
Motor shuts off all of a sudden. This is a dangerous situation. Lets understand under what conditions this is happening. What’s Ather’s take on this?
BMS issue: As I read from message from Mr. Abhishek Balaji, Ather is working on it. But we need a permanent fix.
If Ather could come out with a concrete fix for the above, it would be great for the rider, for the product and Ather as well.
All these pertain to 450 only.
Coming to a must have feature, Ather sadly misses on a side step/foot rest on the left for one sided seating by ladies wearing saree. The situation of having need to ride with pillion seated on one side may arise at any point of time. Are there any after-market fitments available at least?
The rear wheel will lock up in case of emergency braking, since it’s a single pot disc brake it’s is pretty common, freezing of display can be solved by soft restart, press both brake levers and start button for 5-7 seconds and it’s reboot motor shuts of all of a sudden is NOT common many users have faced it in 4.1.1 update but i think it got resolved in 4.1.2 update, Abhishek Balaji have answered this question on another post BMS shutdown got solved in Ather 1.5 version for any other problem your Scooter is in warranty and Ather will replace the damaged part in the said period
Thanks for the clarifications. It helped me.
I think I will design a side step and foot rest and fix it.
Ather will provide screen guard(with lots of bubbles and lines) during service. Only thing is, you need to remind them else they forgot. For me they provided in second on-demand service.
Today given a lift to painter , he asked the normal question of vehicle & never asked about price at all
the question he put on me really surprised me
why there no solar panels in vehicle ? so you get power and charged when vehicle is on stand by
Efficiency of solar panel is very low In world max efficiency is 21% so its not possible to mount solar panel on vehicle. If the percentage goes around 80 to 90 percent then we can mount. Now its not possible.Then you get max power in small area. Now you require large area for small power
You can definitely put panels on the vehicle. But it will not improve your range by much as the efficiency is low and it would be much faster to just charge the vehicle through regular means.
Note: Tesla cyber truck will have an option to put solar panels on it. But it will only generate 15 miles per day( Total range of the truck is around 500 miles)… So it’s not much… But it will certainly help a little.
Putting it on two wheeler will not help
I was talking about vehicle in general not specifically 2 wheeler.
Adding solar panels would increase the total price of the vehicle and electric vehicles already bearing such high initial investment would end up getting even more unaffordable and thus drives out the adoption of EVs.
how much they charged to fix it?
Hi guys. I’m just confused on how frequently to use the mode switching feature. I drive a total of 30 kms a day, so I’m inclined to switch to sports mode more often. I have certain stretches of 2-3 kms in my everyday route where I can actually go beyond 65-70 kmph. So I am switching to sports mode only during those stretches. But as I use daily, I am switching more often based on traffic in a single ride. I feel like I’m using it like an extended gear. Is it okay to switch modes every 2-3 kms based on traffic? Does it have any long-term effects?
You can use any mode as per traffic and requirements; just be safe. Technically, since sport mode uses more juice at once, it should degrade battery faster in the verrry long run. You might not even notice that degradation.
Personally, the mode doesn’t matter, it’s a matter of driving style that you need to settle on for your daily routine, 30 kms is easily doable completely in sports mode.
Completely okay to switch between modes. The modes are there to just give you extended range and smoother throttle response.
But if you can get decent range in SPORT or RIDE, you can continue to use one particular mode throughout a trip. I used to switch modes at one time, until I figured it was easier to use just one mode throughout, than to get used to the throttle response each time I switch modes.
I do 30kms a day, Exclusively in Sport mode. Almost a year of daily usage and have not noticed any degradation till date.
