So thereâs a problem with scooter charging plug lock not disengaging after failed OTA update:
So today morning, I turned on the ignition, waited 2 seconds, then unplugged the charging plug from the Ather (as I usually do). However, after unplugging, a couple seconds later, the screen suddenly started to show that it was updating for a split second, and then the dashboard just rebooted.
This confused me immensely, because why did it start to update after I unplugged the charger? Anyway, I thought nothing of it, but the screen started glitching out, and so I rebooted the dashboard with the both breaks + ignition shortcut. Everything seemed normal.
I then thought, let me plug it back in if it needs to complete some update. However, the lock for the charging plug was engaged, while the charging plug was not connected to the vehicle. The plug would not go into the vehicle fully, no matter what. I tried rebooting the dashboard multiple times, waiting, turning the Ather Dot on and off, locking and unlocking the vehicle dozens of times, nothing worked, the lock for the charging plug on the scooter was engaged, while the plug was out of the vehicle. This prevented me from charging the vehicle as well. I then proceeded to do a full shutdown of the vehcile (from the settings), and then turned the scooter back on, and finally, it unlocked, and I was able to plug the charger into it.
However, even after plugging it in, there was no OTA update or anything poping up now. Can someone confirm that 4.0.4.612543 is the latest version?
It is even more scary to think about the scenario if this happened while the plug was plugged into the scooter, or if it happened at an Ather Grid location.
I think the way that OTA updates are handled need to be looked into, I can imagine that this happened because an OTA update initiated with some lag, hence tried to initiate after I unplugged the plug, and the scooter thought the plug was still plugged in, so it engaged the charging plug lock and tried to do the OTA update, but then bailed when it realised the plug was unplugged, but then did not disengage the charging plug lock after bailing.
Maybe the OTA update process should not just bail when this happens, and show a message like âOTA update cancelled because charging plug was removed, will try again the next time you plug in to the chargerâ, and also make sure to unlock the charging plug lock when this happens.
