Scheduled shutdown will be a good alternative which allows us to shutdown and also avoid losing the ride statistics…
But, when I spoke with Pradeep at Open Forum, he told that fix is planned where the unsynced data will be persisted during shutdown and it will be synced later when the vehicle is turned ON…
I am not sure about the timeline for this. But, if that is planned, we would not need a scheduled shutdown…
I would like to have Two charge modes:
a. Eco mode- slow charge where the drawing current is reduced. As I run all my 5 amps needs at my home on solar. Currently I am not able to use it as the load is high on the solar supply.
b. Normal mode to allow other users charge normally.
again from observation - it is negligible! - wouldn’t impact much even if u r not using.
for reference
when i came down from Tirumala hill at tirupathi (this is about 19km) i engaged regen for all / most of the time - KM added from regen is just 2km
but effort i have to put to capture regen is high and frustrating (need to hold the accelerator reverse for long time - may be 45min) which is not worth it - instead i must have enjoyed the ride!!
so dont worry about regen much - have a joyful ride
While I have no answer to your question, following is my understanding in terms of network connection.
Network connection remains intact in OFF condition. However it gets turned off in Shutdown mode.
Network connection is not live throughout the off state. It comes live periodically to check this that… (I do not know what are those, I heard it is for BMS check, location check etc…, then I do not know why battery % does not get updated)
I feel this is good way to understand how much battery has lost during the idle period…
True, thats my understanding too… When in OFF, network connection happens once in a while not throughout… Thats why ride statistics appear randomly not just after 7 minutes OFF.
Thought it would be nice to know if it would rain that day before I head out. But then, my phone does the same thing😄 so it beats the purpose. Also, Anagh is right. Weather is very unpredictable and you won’t be able to rely on it much.
