OTA Wants - Feature requests
while agree to above
for now please try searching on map and select to navigate which will be much easier - u can see most closest to ur location and simply select that (both on app and dashboard)
I’m not sure if this is already requested. However, I was thinking if it is possible to have the following
  1. Parking blinkers
  2. Give more data on regen
  3. Cruise control (should not exceed 40kmph)
It will be useful to provide the user with alerts on the Ather app when the charge reaches a certain preset percentage or projected range like 50/80/100 % or say 30/50/70 km or one that the user can set depending on the commute planned.
This will help the user to check only when there is a notification and not keep looking at the app to see how much charge has accumulated.
Also, the red color feedback indicating higher consumption of battery power is a bit difficult to interpret. More red or more green are really relative indicators and not absolute. If the scooter has access to instant kwhr data then why not show that on the panel in addition to the range and speed? I have found the instantaneous fuel consumption feature in my car to be very useful and it helps me get superb mileage out of the car.
Yes we need the instantaneous details.
More info like numerals not intensity of red colour.
Tesla cars indications can be used for reference.
I m not sure if it’s already there, but is there a way to search (or send from app) unnamed location like Google Maps Plus codes
Alternatively, like how you can search a location in Google Maps and share it to Uber app, you should be able to share it to Ather app as well.
Not available now but It’s surely on the cards. During the first owners’ meet, we were told that it’ll come in the future app updates.
@Ather.Team Can we display the distance run since the last full charge? It is a very useful feature to understand the mileage one is getting per full charge instead of going by the predicted range.
Currently I can do this by resetting the trip meters. But it is useful and informative to track this on the app and to see a timeline /trend.
Exactly, very similar to screen on time on Mobiles… now I’m summing up each time from trips…
And trip history takes ages to sync and some times small trips gets missed…
It is good only when 100%-0% is done
It’s good as long as it reached 100%…
At any point it will read ā€œkms since last full chargeā€
After the latest update, I observed that when the range hits 10km, vehicle is going super ECO mode or something like that. Its reaching 40kmph with great struggle. It was never like this, even at low SOC it had decent power.
@Shreyas, just a suggestion, by default it can switch to Ride mode when the range is 10kms, but manually I should be able to switch back to Sports mode. This morning, I was 4kms away from home, so there was no chance of me running out of charge.
Also I noticed, even with this limp mode, range reduced by 4kms for 4kms of travel.
while shutdown option on mobile app will be ideal - not sure if this will be feasible as there wont be a network connectivity… which will consume more energy (if Ather choose to enable)
so, until Ather figure out best way to accommodate this, team may work on scheduled shutdown option on dashboard - may be 1/2hr or 1hr - so that ride history and other stats will be saved and any other info can be sent to cloud before shutdown
How often to you shutdown your bike? What’s the idle drain when you shut it down in the night or for 8 hours? I’m sure there shouldn’t be any. But do you think it’s a good idea to shut it down every night if you’re not charging it?
i lose 3-4km overnight (8 - 9 hrs)
i dont bother much - but because there is lot of concern from other users - i though a scheduled shut is good idea
only twice i tried shut down option and didnt see a big benefit (as the vampire drain is still there about 3km overnight)
is it a good idea! - depends -
i checked with other flight owners who said it is benefiting reducing the loss - so yes it is good idea - why should you loose any energy…
If not shutdown, at least a sleep/hibernate, after all it’s a computer inside :wink:
@Ather.Team, I’m sure if it can cross our minds, it would have definitely been in yours too.
I guess it’s a good idea to shut down for the people who don’t need to charge every night. I charged it to 95% and shut it down at 12:30 AM. Now it’s almost 9:30. And there is no loss. Not even 1% so I would advice people to shut it down in the night who don’t need to charge it everyday.
How can find whether the regenerative power system is working fine and how much was regenerated???
Is any option to see in bike panel or app???
There is no such option as of now.
Scheduled shutdown is very good option… I vote for it… , say after 15 min when the data gets synchronized with the server.
Are you sure there is no network connectivity after we turn off (not shut down)? If yes, then how the data gets synchronized with server after 7~10 min today? Just wondering.
I’m pretty sure that the network connectivity stays on when we turn of the bike. Or else there is now way that the data will get synced even when we turn it off. Scheduled shutdown is an amazing idea.
