Yes, the brand is not clear, though some articles are incorrectly naming random brands including Okinawa.
As much as safety needs to be taken priority, keep showcasing this and spreading this news much is going to hurt entire industry as people will start thinking EV is unsafe.
A mistake can happen in any industry and that mistake cannot be seen as example, rather correct it soon.
Hello everyone,
Everyone who thinks ola is better scooter then Ather, Ola is better just on paper and not in reality
Ather is way better Just Watch this video
MORE THINGS TO ADD HERE ! (FOR OLA )
-wrost after sales service
-poor build quality
-suspension style is better of Ather as in Ather has double frork in front and vertical monoshock at back see the attached photo for reference
Give them time and they will be good. We need more competition. Its good for consumers like us. For me personally, everything is good about Ather except software & low range.
So if there is something out there which excels at these 2 things, I will be happier as I will have more to choose from. Kudos to Ather for pushing everyone and in the process being pushed to do better. Hopefully, a longer range model soon…?
Ola has a Motor driven by a belt and not a HUB motor, you can see a belt right below the suspension, A hub motor is built into the rear wheel and this is not the ola’s case
They have completely closed off motor and BMS hence not enough cooling and only p passive cooling. This is the main reason for motor/battery overheated messages and drop in performance.
