I think @tarun seems a bit little dull or not well. Usually he’ll be very happy and smiling in other interviews😀
Because the topic was so serious.
@abhishek.balaji @srinivasaraju @raghav.srinivasan
Hello everyone, Everyone who thinks ola is better scooter then Ather, Ola is better just on paper and not in reality Ather is way better Just Watch this video
MORE THINGS TO ADD HERE ! (FOR OLA )
-wrost after sales service
-poor build quality
-suspension style is better of Ather as in Ather has double frork in front and vertical monoshock at back see the attached photo for reference
-NO scooter of Ather has caught fire till date
I believe ola doesn’t have hub motor, but belt driven. As seen in wheel assembly pic, you can see the belt just in front of the wheel.
Give them time and they will be good. We need more competition. Its good for consumers like us. For me personally, everything is good about Ather except software & low range. So if there is something out there which excels at these 2 things, I will be happier as I will have more to choose from. Kudos to Ather for pushing everyone and in the process being pushed to do better. Hopefully, a longer range model soon…?
@rajkumar.mishra2010 I believe what you say , makes sense !
If you give Ather also some time it will bring even better product
I am just saying ola has better range nothing else rest all the things are better in Ather.
A person who cares all about is range and nothing else can go for ola
Ola has a Motor driven by a belt and not a HUB motor, you can see a belt right below the suspension, A hub motor is built into the rear wheel and this is not the ola’s case
@power_light2000 What’s so much going on that wheel then ?
Still there are thermal issues with ola in hyper mode while Ather has no issues in wrap mode.
Post By @srinivasaraju
You can see the Motor is IPM, while OLA is struggling with Thermal efficiency and BMS. Ather is not behind in terms of CS and software.
Atleast what Ather is lacking is acceptable
What Ola is lacking is not acceptable
-reverse bug
-thermal issue (already 2 scotters have caught fire )
If you can provide the technology and it is not usable due to some bugs and hardware issues what’s the issue of the technology then ?
They have completely closed off motor and BMS hence not enough cooling and only p passive cooling. This is the main reason for motor/battery overheated messages and drop in performance.
@kgeshwaran Serious issue and can’t be solved over updates
While Ather did it R&D properly and got vent’s near the floorboard to cool the motor
Have a look… Showroom is on fire.
Any comments on this ?
Effort But nowhere close to Ather’s SM team.
They sound like the corny notifications I get from swiggy and zomato to get me to buy food🤦♂Ather handles social media with far more class
This one is epic
True that.
