How do you go below 30 Wh/km? The lowest I’ve gotten is 31 Wh/km.
HOW IS U R RIDING ,can u please explain so tat it may help people like me y coz i bought 450 on 27th feb 2020 but i am getting 50kms in ride mode and i am not driving aggresively please help in tat ather app the efficiency is showing avg of 45wh/km how 2 reduce tat efficiency
The key is to accelerate slowly, keep throttle at minimum. So, it is ok to go fast (top speed) at lower throttles
Enable Real-time Efficiency in the settings menu of the bike.
Accelerate slowly in such way as to avoid the Red halo around your range display box on the bike touchscreen.
Use regen to slowdown before engaging the brakes
Cruise and Coast : Avoid rapid acceleration- deceleration and use the free spinning motor to coast while approaching speed breakers and signals.
If all of the above does not help - lose some weight
wat happens if i always ride in SPORT nd aggressively… i know that RANGE will decrease… will it affect the motor???
Till date, I have driven 8000kms in Sport mode. The motor works as good as it did on Day 1. I use the other modes out of necessity ONLY, not out of choice.
What do think of my observation? Please refer to my post, three posts earlier than this. Being a newbie, I am trying different modes.
Another thing I observed is that a red halo appears when I am on an incline. Size of it varies. Is it that I am straining the motor by holding the accelerator in the same position. Do I need to apply more acceleration to prevent halo?
Good to know about your experimentation. Way to go !
Raghav’s answer is on Motor Endurance test and answer to @sibbuk3 's question and may not be really on range alone.
Out of necessity…request you to explain the scenario.
The red halo shows the energy consumption. On an incline, the scooter is obviously consuming more energy. (do note that there is a slight delay in this and it is not instantaneous). It has nothing to do with straining the motor, in fact in that case of you twist the throttle more, that halo will only increase (as more energy (from the battery) is consumed. even if you ride with red halo for the entire ride, there will be no problem.
Thanks…will experiment more in days to come. Its an experience.
But I did notice that the size of the halo is more with Ride mode compared with Sport mode on the same inclines.
thanks for u r suggestions guys this will help me in future days…will see
When I am low on charge and I need to travel 15+ kms I usually switch from Sport to Ride mode just to increase my range and avoid Eco Mode.
And during those times when i hit the magic 17% SoC then the bike automatically switches to Eco Mode.
next time plz do give the battery % starting point , kms, u have taken & the pic of console.
Thanks… What State of Charge do you consider as low charge state?
