So, 80km prediction is at 100% battery charge level. So at 60%, it would be 48km. Am I right?
Any how it all depends on how the traffic is and what is constant speed at which you are traveling i.e if you travel at high speed long distance battery drains fast and slow speed long distance battery drains slow.App show maximum speed but will not show what is the distance traveled in max speed it may be 1 sec or 5 min. If you switch on the scooter and push for 500 meters then you will get good range…!!!
Yes, pretty much. But it’s not easy to keep calculating the range everytime. Since 80kms is close to the true range in ECO (75), I switch to ECO just to see what range it shows and then switch back to SPORT
Great…by your way of checking into ECO range you are assured that you will reach home and have “Crispy Poppadom”. Thank you for the good explanation.
Dashboard shows the true range which is 75 - 65 - 55 and it will be constant, whereas pridected range in app shows based on your riding patterns and it will be keep on changing.
Already checked in SPORT mode ( 55 KM in full charge)the range give is 100% right you will get it for sure i checked it
There is one old slogan years back Fill it…Shut it…Forget it… for Hero Honda motor cycle . For Now Ather its changed to Charge it…Remove it…Forget it…
Dont count the millage scooter dash board shows exact range not app its only predicted range. Just charge and enjoy each and every moment of riding thats all
Hello All, I’m not Pro Forum person and just a learner.
Wanted to share my ride stats of today’s.
I’m happy!
That is a nice efficiency you got there!
How to reduce wh/km to increase the km And how to use Regen to increase the battery capacity in turn the mileage
Hi this should help you in clarifying the same.
Efficiency:
How to use regen:
Accelerate slowly and prepare for changes in traffic flow.
I’d Initially thought that better efficiency was related to lower top speed. But it’s actually just about making best use of the power you put into the wheels.
Could’ve saved myself some time and back ache if I knew this when I went to Savandurga and Shivagange🤦🏻♂️
Here’s an example:
Getting a good efficiency on flyovers and highways is easier. In the screenshot below, I’d actually kept a constant speed of about 45-55kmph. Gathered some speed and kept the throttle position constant while climbing flyovers. Coasted, and maybe even accelerated a bit while coming down, depending on whether I’ll have to slow down or climb another flyover. If you prepare for what’s ahead of you and use regen or acceleration accordingly, you will see better efficiency numbers.
Accelerating gradually is probably difficult though. SPORT mode detects even the slightest change in throttle movement. It’s easier to do in ECO or RIDE mode. It might take some time to learn to throttle slowly in SPORT mode.
Trying to push my efficiency numbers lower and top speed numbers higher
Thank you! I was happy indeed as Sports Mode giving such performance : )
Great Examples and explanation
Thanks for sharing…
Hey even i stay at ecity. We can meet up sometime
definitely Bro. where do you stay in electronic city
I stay at Doddathoguru
