And do let us know the driving conditions, terrain etc.
Bangalore’s terrain is not as flat as Chennais… so range numbers will obviously be better in Chennai.
If we could use regen to 20-0kmph also, maybe the range numbers will increase…
How is the traffic in Madras compared to that of Bangalore?
I understand but looking at predicted ranges of 120 was unheard of.
I think If we could have changed the strength of our Regen we’d be able to get much much better efficiency figures
Tesla’s efficiency is 160 wh/km which is a 1.7 ton car and a large portion of this is because of the very strong regen.
You can get a gist of how strong the regen is in this video
I think Ather should seriously consider strong regen to make Ather more efficient
Ignore the predicted range for the first 1000kms. You only have 300kms on the odo and personally speaking that is not enough to predict range.
This FAQ might help with how to extract the best mileage.
Now a days most of the indian metro cities have good amount of traffic, however chennai is not far behind Bangalore.
Sir,
So far I have covered 8k km. In my openion
travel @30-35km leads to 100+ range. You need to maintain tyre pressure. When you have 450 don’t compromise on short distance instead choose a good road. Recently I got 106km.
Damn! I’m jealous of the terrain in Chennai now
To achieve such huge range what is the efficiency of your rides?
This range in Chennai or Bangalore ?
Even i am facing same issue
I maintain the efficiency between 20 to 22wh/km.
I am from Chennai.
What is the speed you go normally and how many km you commute daily?
I try to maintain the speed between 35 to 45 kmph during my daily travel of 72km (home to office to home).
in which mode you drive?
Most of the time i use ride mode.
