Hi, I’m looking for a suggestion here regarding the dot. My scenario is, I live in the second floor and yet to gain permission for dot installation and my idea was to purchase a travel charger but now that travel charger is out of stock, I’ve to make some alternative. My expectation is to temporarily place dot at my balcony and park 450 right down and get it charged. I want to know if there is any option or adapter which can be used. ie, a male connector which I can plug in to dot on my second floor and run it down to plug it to 450. Pls suggest.
You can’t extend the cable from the Dot to the vehicle, but you can get a 3 pin extension from your home socket to the dot, and place it near your vehicle.
Oh ok. I thought that as well but carrying dot down and up would be inconvenient.
Ather Dot is 3.6 kilos. Portable charger is 2.6 kilos.
You should tell this to people who want swappable batteries
@abhishek.balaji please officially christen the portable charger as Dash. Dot and Dash - this is also in line with Ather’s love for morse codes
Thanks Hemanth. That sounds good then. Simple as that and also helps me do a little bit of warm up . Environment friendly and healthy…
This is a solution only if it is temporary as you’ve mentioned. I wouldn’t suggest this as a permanent solution for sure.
Ather Dot installation is scheduled on Saturday, 22 Feb 2020. I reside in the second floor of my apartment. I wish to lay a cable from a 15Amp scoket in the utiities area of my flat to the Dot that I would install in my parking slot in the basement. I do not wish to draw wiring from the meter. I need to have switch control to prevent power theft. What sort of cable must be laid? Is it a three core cable? Kindly advice. Thanks.
I doubt power theft will be a concern with the authentication that happens for when you plug the charger. Only your Ather 450 can be charged your Dot.
I meant power theft from the socket (to which Dot will be plugged in) in the parking lot and not from the Dot’s output.
AFAIK, the DOT does not come Pre-fixed with a male plug. So instead of fixed a socket and plugging the DOT in, why do you just directly crimp it to your main line from the meter (add a MCB in between as a 2nd later of protection)?
No socket, no power theft!
Thanks. If its so, I have not issues then regarding power theft. Would MCB (second layer of protection) be part of Ather’s scope?
Check this post to get a good sense on installation: https://forum.atherenergy.com/t/ather-dot-the-new-home-charging-pod/3435/95?u=abhishek.balaji
I have opted for Self installation of Ather Dot, May i know weather PRCD is included in the Box or we have to purchase it from outside sources @abhishek.balaji
Dear Mr. Mayur, I understand you opted for self installation. Please let me know the guage of the cable you used from your mains/meter until the Dot. What should be the current carrying capacity of the cable? I am planning to draw a line (approx. 30 meters) from the service utility area of my flat in second floor to the parking lot where Dot will be installed. I need to have switch and socket arrangement for future use.
Hi, I just got the installation of home charger done today by Ather team. They had taken the connection from a normal 3-pin socket from within my home. I’m not sure if this is still the fast charger. I had seen pics in forum before that they take directly from meter. Can anyone confirm this is right installation?
This is normal charger.Not fast charger.Durinf open forum discussion i inderstood that fast charger costs about 30-40k.This installation is quite simple one.You can take from meter also if it is near to it.This also seems okay.
Does this mean I won’t be able to get 80 percent charge in 1 hr? What is the actual procedure to get the actual fast charger installed directly from meter? Why is Ather not informing this on payment page or during installation? @abhishek.balaji can you help understand the different chargers and installation types done. I was hoping all customers get the same.
This is the charger which are given to all.Of you want to get 80% charge in 1hr,you have to charge in fast charging systems available in ather charging stations.This is overnight charger.Fast chargong reduces the life of battery.In case of emergency and charge on the go(to avoid range anxiety) fast charging to be used.Ather doesn’t have on the shelf fast chargers.Even you install from meter, you will not be able to fast charge.It requires fast chargers and that costs 30-40k.Are you ready to buy it?
I just now went through all faqs and forum posts to understand the differences between dot charger and public fast charger. Ather is clever in advertising about fast charging and the battery capabilities but never explicitly say anywhere that home charger is not a fast charger. Now I get it. BTW I would have been okay buying the fast charger considering all public points are very far away from my home and mine is an independent home as well.
Two types of chargers:
Home charger
This is the one you install at home, and is used to charge your scooter most of the time. This is meant to charge overnight when your scooter is in the parking lot and idle. Installation can either be done through any switch box or directly to the meter.
In case you live in a multi-story apartment, your meter would be easier to plug into since this would be in the parking lot where your scooter is parked.
In cases like yours where there’s a 5 amp socket available and you live on the ground floor, we can draw the cabling from there as well.
Charging time for the Dot is around 3 hours for 80% and 5.5 hours for 0-100%,
Fast public charger
These are units we install in publicly accessible locations like malls, cafes, restaurants etc. These cannot be installed at home since they have a much higher load, and are significantly more expensive than the Dot. Fast chargers are meant to be used for quick top ups when you’re around the city. They are not feasible for everyday use.
Charging time here is about 80% in an hour.
