Anyone noticing weird BT issue with the vehicle? Like it connects and disconnects every few seconds. It works fine when you unpair it from the app and dashboard but the next time you use the vehicle again, it does the disconnect & connect behavior again.
It’s getting a bit annoying since it’s a really useful feature for me to let people know that I am riding so ain’t answering their calls.
Weird enough that this happened right after latest app update of 10.5.0
Hey guys,
So there was an emergency this morning and I had to rush to the hospital, like always I had set my bike for optimised charging till 5am and slept. When I woke up at 7.30am to my shock my bike was asking to install and update and remove the charger, did the same but to remove the charger you need to keep the key in ON position, then the update display installing, KEEP THE KEY IN OFF, and I’m like, what? I did that and it was literally stuck for 10 mins on 48% and I was like, I need to rush. Why can’t these updates automatically or like we should have control to install these manually. For god sake if an update gets corrupt then this EV wouldn’t even start.
Horrible Day!
As per changelog, This is the Exact issue they are trying to fix.
After this update, you will get notification to accept downloading the update, it will install automatically between 2 am and 4 am if the bike is off and battery above 40%.
Hey Aaditya, we’re dedicated to making your Ather experience truly exceptional. To help resolve this quickly, Could you please DM us the Case ID of your concern raised on the Ather app? If you haven’t raised one yet, simply use the “I have an issue” option under the Support tab.
I gotta ask.
When in traffic on a straight road just for a few minutes the motor when idle shuts down, is there any particular way wherein you can directly start the bike? The motor status disengages in the dashboard. I try racing, pressing the brake + start or just the start as well, nothing works, I need to turn off the bike and turn it back on then it resumes. So like is there a proper guide to this? (No side stand is engaged)
Also, the bike claims that the top speed is at 80kmph, and when on zip mode you get 85 mileage, but during riding only on zip mode for a continuous journey at top speed drains the battery like crazy, odo clocks at 0.56km and 1 km drops from the range, so does it happen to everyone? If it does doesn’t this optimisation should happen from the OS or proper battery stabilisation to ensure that you get 1km clocked on odo & 1km drop in range.
Max I have got around 62 mileage on zip mode( purchased the bike in mid Nov)
Lol, faced one just a few minutes back. I had to go to a relative’s place and since I was not exactly sure what route to take, I sent the location to my vehicle.
I don’t know why it kept recognising it’s location as being somewhere near Alandi (around 30 to 40KMs from my actual location). I tried rebooting the scooter but it didn’t solve, finally I got an idea that I’ll save the address in the app and access from scooter itself as scooter was having the correct location but the app was messing it up for some reason.
So I added the address in the saved places and accessed it via the scooter, worked like a charm. When I checked the app when I reached their place, it solved the issue. Not sure what was causing this in the first place
I have not received update of propack after 27 days of vehicle invoicing. I am following up to the service center but they are also not having answers.
