They explained the gyro sensor function but how is the scooter locked into position needs clarity
I loved the part where you were speaking, concise and spoke the mind of true young tech enthusiasts ,would love to connect with you as a fellow college student
Even i have updated new Software 5.1 still my old Gen 3 450 X is not working Auto Hold Function
Try after this jan 25th it will be rolled out
Got the new Ather stack update but the Autohold is not working. Took the scooter to a incline, made the speed to zero by pressing brakes. When released, itâs rolling backwards.
Bluetooth connectivity on the dashboard always shows âconnectingâ
Laggy Swipes, previous UI was better
Data Sync to phne app is not proper
TPMS giving alert has âpuncture in front tyreâ while everything is ok.
Overall experience not good was fine with previous stack.
Can you help Sir. @ather
Same issue here. Auto hold enable option in quick settings not ahowing up. Bluetooth is choppy. At ondranagar showroom they told me earlier this werk that auto hold is only for gen 3.1. Is that correct
An update on auto hold it rolls out only on jan 25
I got the latest update yesterday
Check if Autohold function works?
Are you able to view Autohold option in settings? If yes can post a snap here Autohold is not a option in settings. Itâs a behaviour of the vehicle that in inclined surface when release the brakes post coming to zero kilometres the scooter will not roll by itself
Ok, My Ather 450X Gen3 received update last night but Autohold feature is still missing.
The snap is from which Ather Gen model? Is this Ather 450x Gen3 or Gen3.1 ?
And can you tell me that when did u receive the update?
This is from 450X Gen3, This is from Atherstack 5 (11.5.1-202301) for the latest one they have removed Autohold for testing. This was a normal update which was received.
I went to Ather app Ota update & Found this 11.5.1-10.5.1-202302
This is my atherstack version @puttalewis
Same is for me
Will the Auto-hold works if the motor is of while parking the vehicle in incline or decline roads?
When the motor is OFF, the system is also OFF. Therefore, the auto hold feature wonât work.
The system never gets switched off eventhough you remove the key from the vehicleâŚThe system goes offline only when you shutdown. Autohold is a feature which focuses mainly on the motor and not on the brakes, since the motor is turned off the motor wonât be able to provide enough resistive potential to the inclined surface and so autohold doesnât workâŚ
When the motor is OFF, it doesnât provide any power, regen or resistance, not even a little resistive voltage/potential.
