A reasonable answer which I now realise I could have pieced together had I thought about it for a few minutes
i havenāt received it yet
@Ather.Team my understanding was that the charging cable cannot be unplugged/removed from the flight without the key inserted.
However, noticed that the cable can be unplugged from the flight if the MCB of the home charging pod is switched OFF after charging. Is this correct or is my home charging pod misbehaving? @Shreyas
Please clarify. Thankyou in advance.
I had similar question before and hence taking liberty to answer you.
Yes, without the key turning ON, charging cable cannot be removed as there is a solenoid which locks. This is true for our home charging point cable but I do not know how it is for standalone charger.
Above case is true irrespective of grid power present or absent. Meaning, MCB has no role in removing solenoid cable.
At the outset, thanks for the answer @rajeshkav .
With normal effort (means, not by force) and without putting the key - am able to remove the cable by switching off the MCB. Will try tonight if I can remove the cable when its charging (again will not force as I donāt want this to be damaged) - i think NO for now. Will confirm later tonight.
NOTE: Iām using the home charging pod and not the 5A/15A cable.
we CANNOT remove the cable when the charging is happening. however, the same CAN BE removed once the MCB is turned OFF without inserting the key. Note, this is from home charging pod and not the Ather Grid.
@Shreyas @Ather.Team Is this expected?
Looks like your home pod has some issue. Please call customer care.
Without inserting the key and turning on the scooter, you SHOULD NOT be able to pull charging cable as there is a solenoid that will lock. Upon turning on the key, you will hear a unlock click in a good system. This is irrespective of power present or not.
yes, I should and appears like its time to call them.
thanks for sharing your thoughts, expertise.
Another things is my home pod is showing FAST CHARGING although I know that this is not the case for the personal home pod installations.
I apologize for my comment above. This morning I checked in my home charging point, it behaves similar to what you saidā¦ When there is no power, without the key, I am able to remove nozzle.
@Shreyas , is this acceptable behaviour?
If the solenoid gets disengaged without the key, then I feel it is wrong. I remember Tarun saying this in the open house that key acts like security/safety where other users cannot just pull out. Or is this applicable only to Public Charging?
Lets take this case. We are charging our bike in home/public pod. Without the ownerās will and wish , other user should not pull out to charge second vehicle.
Earlier in your reply, you had indicated as below.
no problem, thanks for promptly updating or reverting. I was planning to call customer service tomorrow to schedule a visit. Meanwhile, it would be good to get an answer from @Shreyas or @Ather.Team
Looking into it. Will update you on this soon
Weāve identified this to be a bug. We are working on fixing this at the earliest and this should come in with the next OTA update.
The intended behavior is to keep the connector locked in place irrespective of power going in the vehicle or not once connected. Only the key-on should unlock the connector from the vehicle.
Appreciate your quick answer. Thanks.
@Shreyas my home point started glowing red today. Did the switch off-on dance with the RCCB, but still glowing red. It was working fine (green) until an hour ago.
What should I do now? Donāt have the bike yet, so donāt ask me to plug it in
You may check after some time., say an hour or soā¦
RED might be because,
- input voltage might be above or below the expected range
- there is leakage from line to neutral or line to earth (you might have defective instrument at home, please unplug all and check)
- if above does not , call customer care.
And do remember to update here for everybodyās interest. All the best and wish you speedy recovery
And one moreā¦ please remove all the plastic wrapping. Electronic circuitry inside requires air to flow.
Switched it off now. Will try again tomorrow morning
Checked now and itās running green.
Could have been a voltage issue. There was a day long power cut till about 6pm.
Like @rajeshkav suggested the point was hot and shutdown to avoid a thermal failure ?
Good to hearā¦ Just watch out these. If you have voltmeter at home, you may watch whether it is voltage issue. I strongly suggest you to remove all plastic wrapping.
I donāt get why in India people keep their electronic products covered, they need to dispate heat.
Only in india have I have seen people not removing the plastic cover in appliances, tv, car seats/mirrors even after years.
