Upload option is not working at all in app. It is not a good experience if we have to always log from a laptop to upload images.
No one please suggest to open through browser in mobile itself. (This point is important since there are lot of talented people around who can suggest this)
I guess this is a known issue already, Hope a quick resolution on this.
I get the below error trying to share location to Ather aap from OSMAnd+. Can this be fixed? Or is ather going to support only Google?
time: 1631997664099
msg: java.lang.NumberFormatException: For input string: "h"
stacktrace: java.lang.NumberFormatException: For input string: "h"
at java.lang.Integer.parseInt(Integer.java:615)
at java.math.BigInteger.<init>(BigInteger.java:474)
at com.athermobileapp.utills.googleMapUtils.MapUrlExpander$expandUrl$2.invokeSuspend(MapUrlExpander.kt:67)
at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:106)
at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:738)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
I think this is because the map details shared by the map apps are different. Can there be a workaround at least?
Ok I just found it. Ather app expects a Google maps link that goes https⦠No wonder the app threw NumberFormatException. Osm would be sending a number instead of https.
Well it seems Ather has been working with these guys since inception. So not sure if acquiring them alone will get us improved software experience. They need a much bigger overhaul. IMO its either difficult for Ather to hire talent or the talent just doesnāt exists⦠Haha
@abhishek.balaji It will be great if you can add city specific Helpline numbers in the app. I had to call the service center in Delhi and the number in the app connected me to the Bengaluru Helpline. Depending on the vehicle Registeration or owner details you can probably update the numbers in the app or have a drop down in the app for selecting city before dialing.
When will the next internal update arrive??? Itās been since a month no news nothing from Atherā¦dint except this would happenā¦facing bugs in scooterā¦
The team is working on a fix for the sync issues that all are facing. There has been a revert to the beta release so that a comprehensive update can be pushed.
Meanwhile, Ather does not need Android One type monthly updates to "Fortify your phone with the security update from Google, ⦠" and more time the team gets to work, the better the next release. So,
Is my understanding correct? Updates over the air are supposed to happen even if one is not subscribed to to a connect plan.
Its not only the updates to the scooter but the Dot charger too gets updated when its connected to the scooter and when update is available. One should get missed out on updates to the charger as an up-do-date charger is equally important.
