I’ve used the axor fog film for the past 6 months or so and I can tell you that it’s pretty good. Even with a mask and rain, it doesn’t fog up most times. Alternatively, you could buy the zeiss anti fog spray and coat the inside, should last you about 2 days or so on one application.
Why would you need a fog film for a pinlock compatible helmet? A pinlock visor works much better than this. I’ve attached a picture for you.
Yup. I will warn you though that it’s prone to scratches and some sort of condensation build-up that I’m not able to clean properly, might have to try claying or something.
As per my knowledge you can add extra accessories in your vehicle, i also add a footrest and a center stand, if its void warranty then you can remove the accessories before avail any warranty.
