Whatever is the retailing price at the time of your full payment will be applicable. If it reduces for some reason, you can be happy. If it increases for some reason…tough luck!
Whenever you cancel, you’ll get back full refund. Ofcourse without any sort of interest or any promotional credits if applied (like in this new referral scheme)
Hi this is to just inform u that pls consider feb 29th as ur payment windown open date if it opens earlier also its better right but by 29th feb it will and must open dont worry😇
My pre order number is around 32xxx.when can I expect the payment window to open.? Bangalore is my location.
Does this also apply to the 450X collectors edition scooter pre booking?
Congratulations
Thank you.
my flight is ready to take off my order id 183xx payment window open today ie 10/2/2020 opted for leasing
On lease for what period?
3 years
Should we really go for dot charger? Why not only portable charger? Request for comparison between the two other than being portable.
Should dot chargers remain ON always?
(upload://w0rdjERBirCQkob8spj0BoCmtXD.jpeg)
Now the wait is about to finish received my DOT today have opted for self installation
Payment:
Can multiple payments be made towards completion of payment by the due date? Ie partially by net banking and by credit card.
Would it not turn out costlier at the end of three years?
Total maintenance, Insurance and Ather subscription free
We should ask ather to provide dc fast charger …which they r installing outside on their grids
Frequent fast charging is not good for the batteries. Slow charging is always better and fast charging is ok once in a while but not daily. Hence ather does not install fast charging at homes.
Do let us know how easy/difficult it is to install.
It’s very easy …you have to just drill 4 holes and tighten it…
3 pin plug is also given with it …just see color coding in booklet and plug it into power supply …the only struggle will be be take power supply where you wants to install it …
If you want extra safety …you can install one of these .
But mostly it won’t be required as it will be already installed in our house supply…you have to just check. if you are giving supply directly from your electricity meter…then this is required.
Yes u can do part payment. Balance due will reflect after part payment.
