Yes, i tried but it didn’t work
Might take a few more minutes after its 100%, look for “unlocked” on the dashboard, and then you can remove the plug. If it doesn’t unlock, raise a ticket.
Disconnect it for your use
I thought that ola had already bragged about how many ola hypergrids were going to be set up Looks like they are all faulty like the ola scooter itself:joy:
Situation of Ather Grids is very bad in Hyderabad. According to my personal experience around 70% of the grids are down and the mostly all the working grids are occupied.
I know raising a ticket inside app will result in faster resolution but I could have done that if there was 1-2 grids having this issue. Even one of the grids at Ather Space is not working.
It’s high time Ather should look into installing some more grids and fixing the faulty ones.
People can’t even be dependent on grids here for even 10-15 mins of charge
@Owners-Hyderabad Are you guys facing this issue frequently too?
Yes. I’m facing the same issue in Hyderabad.
i Agree with sumanjay,
i am dependent on grid charging most of the times as in my gated community there’s no option of installing a charger or using portable. there ae 3 grids near me Almond house Kukatpally, Ather space and near zozos pizza. most of the times almond house is down. security guard says its turned off intentionally.
Hey Hereen, you might wanna know that charging the scooter too frequently at Fast Charging Ather Grid is not best for the battery health. Your primary source of charging should be slow charging via Dot/Portable charger. I understand your situation with the complex you live, but you might wanna try to convince them, considering you want your battery health to stay well for a few years.
The charger at hilite mall calicut is not working from last week the charger is shown as available in the app but when connected to the scooter it is just stuck at the initialisation stage The plug outlet is working though I think the problem is with the fastcharger
Please raise this via the app and the local dealer.
Which app?
Quick chat option on the Ather app
Simply tweet @atherenergy at twitter.
Hey @abhishek.balaji been to Patel’s Inn Grid point a couple of times and it’s always switched off. I keep asking the staff and they don’t respond. They said they don’t know
Please ask them to switch it on or at least take it off the Grid all of its not functional anymore.
Last week I was running out of charge, been to Patel’s in and guess what charger was unable to charge the bike, it kept blinking but bike display shows not charging, really very unreliable experience with Ather grid
I work in Manyata campus and I have Ather 450+
Hello , today at kamanahalli Ather grid one scooter was charging and had reached 85 percent and it said locked on the screen but when i tried removing the charger lightly to see if it was locked it wasn’t at all … Has that 80-100 charger unlock been implemented ?
I went to that same place the other day…but they said the grid was not working and said the fast charging is working very slow. I think more Ather grids need to be installed in south delhi.
I know this topic has been dealt with before but. Is there really no way of utilising the 15A 3 Pin socket at the chargers while using the Ather charging cable? Because the Cable is anyway DC power coming from your charger and the 3 Pin is just a regular 15A AC outlet.
Been at Orion mall bangalore and other chargers and seeing an Ather being charged almost always.
