Yes, I am facing same issue, Bluetooth is Stable, but the Connectivity is not stable, In my case there is 0 towers, in fact maps work very well, But mobile app is not in sync.
This happened after the recent Update.
Either I need to reset dashboard or restart.
To reset the dashboard do following.
Press both brakes and at the same time press power button.
Hold it for 3-5 seconds. It will reset the dashboard.
My new Ather 450plus software update version is 11.1.0-202244 after updating software the Bluetooth logo showing in dashboard but am not able to connect or operate the Bluetooth.
450+ doesnât have bluetooth (it is locked via software)
For everyone after the latest update there has been many problems on BluetoothâŚBut for me itâs working flawlesslyâŚEverytime i turn on my Bluetooth and enter the Ather app it connects with the scooter rapidly and never disconnects (even after 121 mins of riding noticed that it didnât disconnect with my phone and the controls work perfectly for me thoughâŚDonât know how this happens
Same here it connects very fast now and is stable
I am facing range issue as earlier it was like drop of 6 to 7 KM depends on road and riding style. But after this update it is like drop to double like 14 - 16 KM. I ride only in Smart Eco and Ride mode only.
Still not have received update for Ather 450x
Even I havenât received the update for my Ather 450X Gen -3.
Battery is draining alot even after shutdown. Charged 100% around 8 pm yesterday. And after 13 hours starting battery it has already drained 3%. It used to drain 1% max in 3-4 days. This issue is after the latest update. Scooter does not wake up from shutdown till I turn the key twice.
I observed it yesterday, when my battery was 100% it is to drain 1% only. but when the battery was 72% it drained around 5%, battery was 67% in the morning. it was normal switch off, not shutdown.
in winter voltage drops rapidly and also at low SOC, i parked at 7% last night and it was 0% untill morning
This is the first time I had issues with actually pairing. It failed to connect. Re-start didnât work. Unpaired and repaired which took some time but it did finally. Fortunately, the connection stuck for the duration of the ride.
Also, Send Location to scooter works well.
My Ather still has bluetooth issues it gets disconnected while driving need to restart everytime the software experience hasnt been for past 3-4 months you guys take too much time to fix the bugsâŚ
Facing a lot of issues with the sync after the 11.1.0 update in Gen 3. The Battery status and ODO does not sync. And maps is not working in dashboard due to connectivity issues.
Yes i had a issue with MAP today. when i search for a location it wont provide any options below also when i click enter it was not able to search that location, Network was full. After i switched off the scooter and ON it back after a long time it was working.
Iâm facing a lot of network connectivity issues. The network drops everyday around 3 AM, and that is when the app stops syncing as obviously there is no connectivity available in the scooter. Until today a restart was fixing the connectivity. But today the restart does not seem to fix the issue as well.
Anyone else facing the same issue?
I too faced the same issue, after reset (Hold Both Brakes (Front + Rear) and Press the start button, all at the same time) , i have no problem for the past few daysâŚ
@abhishek.balaji there is definitely a greater battery drain during shutdown. I again observed a drop of 6% in 2 days. This is happening since the past 2 updates.
Please note this is during shutdown. If shutdown is draining the battery like this i can only imagine how it will be with normal key off.
Also if your battery is around 70 to 80% it drains too fast overnight like almost 4 to 5%, but when its 100% the battery drain is 1 to 2% max
