The navigation is surely back to been worse. 10.1.6 was sooo good for maps and navigation. Just to get an automated dark light theme, they messed up with navigation.
Today I tested rode my Ather 450x only in Sport mode and I got 87kms rage.
I have maintained constant speed from 50 to 65 kmph most of the time and some times reached 75 kmph. Here also I have used 30% of throttle to achieve 65 kmph speed and maintained 60kmph constantly. Do not use throttle more than 30%.
My observations
To get range about 110 kms ride the vehicle in ECO mode by maintaining 25 to 30 kmph speed.
To get range about max 100 kms in ECO mode by maintaining 50 kmph speed.
To get range max 90 kms in Sport mode by maintaining the speed of 50 kmph to 65 kmph.
Here I am attaching ride statistics of todayâs Sport mode ride.
Thank you for sharing your observation⌠I did notice that range in ride mode increased⌠But never minutely analyised it. Will try your way of breaking the 100 mark.
Its very simple tbh. Just donât keep accelerating all the time. Let it roll as much as you can. And avoid hard acceleration and brakes. Essentially thats how we should ride or drive any vehicle.
Bro if you ride the scooter, brakes must be use. Because I am living in Jaipur city, I have to use brake and now is the problem. Ather software is not good I think old os is better than now
Could you be a little more specific so as to which issue you are talking about, so the other members can know as well as the team could help you better?
Since the time of this update released, I have faced a sync issue, but that was solved once I logged out and logged back in on my app. The maps have worked flawless. The dashboard hasnât restarted in the last couple of updates now. The efficiency hasnât changed at all, is as good as before. This is just me sharing my experience with the recent update.
I hope this is correct at least for you, since somehow software experience is not the same for everyone. But for most of the customers with 10.2.0 update maps got worse again which is the best in 10.1.6.
Has anybody noticed that the drop in charge overnight(not in shutdown) has reduced a lot like earlier I used to lose 3 -4 percent charge overnight but now only 1 percent .
How many of you noticed the disconnection of Bluetooth when the dark mode turns on in the middle of the ride. Bluetooth connects perfectly when I start the ride at 5:55pm, but gets disconnected when I stop in the middle (of course after 6pm) like at a traffic signal when the UI changes to the dark mode.
This had happened to me when the feature was in beta stage, I had reported it then. Hasnât happened after the stable build was released. I usually take out my Ather around 5:55pm on weekdays. The switch to dark mode happens during the ride and bluetooth stays connected.
It happened to me even in the stable build recently. I was in the middle of ride last week and stopped at a signal and time is 6PM then, observed that the theme changed to Dark theme and immediately bluetooth is disconnected.
When the bluetooth is disconnected, it is not going to discoverable mode again automatically and it wonât automatically connect to the phone.
I tried tapping the bluetooth icon for changing it to discoverable mode, but immediately due to green signal i have to go forward and bluetooth is not automatically connected to phone even though app is running in the phone and bluetooth on bike is now on discoverable mode.
