All documents? Some owners reported that only one document can be seen
This can be a Solution bro
We can Unlock thru Our Ather App , after 80%
If you charging and The Veh is 80% and plus
If i want , I cant stop it from my app
Thatโs what bro,people should agree with it right??..What if people say I want 100% charge as I want to cover a long distance and argue like that??..We canโt go with them and see where they go right?? .So unlocking the charger through app is subtleโฆ
After the latest 5.3 update, the duration of each ride is either in 3 digits or more than the orginal duration in terms of mins. Please look into this bug and fix the sameโฆ @melvin.wilson
Thambi , I said Whoever near to the Grid can Access to Unlock the Solenoid from their Pwn App Dude
Is there a solution to this? Like a soft reset or something. After the update my 20 minute ride is showing as 72 minutes in the app.
is the rollout of the update for gen 2 still going on since I have not yet got my 5.3 update?
Canโt understand thisโฆWhat if people just randomly unlock grids located in other places??..That will become a nuisance right?..
Simple solution to grid changing limit is to offer an unlock button on dashboard after 80% is completed. So that the users can still use the grid without range anxiety and let other use if needed after 80%.
this shouldโve been the solution from the start. idk what the team smoked when they decided 80% is the limit
There would be fights people will argue with others for getting their scooter charge 100%. Not everyone is understanding in this world.
All the Phone has GPS , We can Check their Location
Those who near the Grid can access this feature
Map still not work navigation arrow not moving
I got it a week back. Still you havenโt received it?
Hi Abhishek,
The scooter should continue charging beyond 80% with an option provided on screen this will cut off the current from charger to scooter. Once it charges upto 80% and if another owner has to do a quick top up. He can stop charging on screen and charge his own vehicle. If there is no owner present then the vehicle should continue charging till 100%. Hoping this wonโt be a challenge to implement.
not yet bro am still waiting
Is anyone else experiencing issues with the navigation system after the software update? I used the navigation twice and both times the reaction time of the pointer was too slow. As a result, I had to take a longer route than usual because I missed some turns. The navigation worked well before the update.
Got the 5.3 update but after it started when i checked optimised charging it was not there, then i did reset with breaks indicator and start button but after that switched on still it didnt show . Not sure why will check again tomorrowโฆ
