Yes I read the Post on a Hurry and I replied ![]()
Apologies ![]()
I have few Frustrated Customer, I will check and Let you know on WhatsApp ![]()
Apologies ![]()
I understood the concern that most poeple will not be taking out their time for this. But something like an online petetion will only take 2 to 3 min of ones time.
Online Petition is useless bro
Oh. I didnt know that. I was thinking it would carry some weightage.
Have done lot of Online Petitions but never got Solution with that
Oh ok. I didnt know this fact.
My steering on the rizta s has gone tight suddenly, what’s up with that? Also there is inconsistencies in the regen when battery is high vs low which makes driving inconsistent and hence unreliable, that definitely shouldn’t be the case
Yes I have also felt this handle getting tight to turn during low speeds and sometimes the bike goes out of control, do anyone know the reason and solution for this handle stiffness
Just take tape ie transparent which has both gums ie for car they use ie windshield purpose they use cut small small and stick inside were gap is there it will solve the problem 100%
First it is dust collects in front shock absorp clean it from water then run it will clear i also has same problme got solve d
Thanks for tip. I got it fixed during service last week. Apparently it’s issue with most of Riztas. Looks like manufacturing defect/oversight.
Anyone please check odometer of your rizta I’m compare with the gps(odometer). When my rizta completed 1km in gps(odometer) it shows 0.91km Means 90m diffrence in every 1km. I have rizta z 2.9kw Please check with your rizta.
Could be a reason of a delayed reading ? Cannot be confirmed unless used another legit method is used
We are aware that 450X has a deliberate error with it’s speedo. It shows 90kmph in the dash while a VBOX will record only 80kmph. This could be due to the same reason. Again looks like display is lagging which is common with Ather too. A restart might help to bring that up to speed.
Refer this - What's Your Top Speed on Ather? 🤔 - #21 by raghav.srinivasan
80 KPH is the Actual Speed of Ather, 10% Increased as per RTO Reason
I check my ride state where my top speed is 73 but my gps speedometer record it 61 only
Even for me it happened… Opened it up added few toothpick pieces in the notches inside and its good as new
Same issue with my Rizta
Bro said true more difficut in night then turn
