Ather Rizta design Issues
I’m curious why Ather isn’t collaborating with petrol pumps to install charging stations with their own power supply and meters. Right now, my Ather and I are in direct sunlight with no shelter.
Some java errors it is showing temporary solution is hard restart every-time we get maps issues .
I am facing too many issues with my Ather Rizta 2.9 Z with pro pack
  1. Stiff handle bar, sometimes just not able to control the vehicle.
  2. Stiff suspension, my family members dont want ro ride pillion as the suspension throws them off the seat over a speed breaker.
  3. Back seat entry / exit is so difficult as with the backrest noone can lift their legs over it. Again noone in family wants to travel pillion.
  4. Today I had my indicator turn button suddenly working as a joystick. When I turn the right turn switch, screen takes me to menu.
  5. Reverse button doesnt turn off after multiple attempts. Sometimes feel that I am stuck in the middle of the road with the reverse mode not turning off.
  6. Maps get stuck when trying to send from phone.
  7. Auto Hold is the funniest feature, it doesn’t engage when you need it the most. It gets engaged on a plain surface when I apply brakes.
  8. Didn’t switch on yesterday when raining after stopping and starting again.
Such a worst quality Ather is becoming day by day. Motor doesn’t have any Cooling Fans now and their R&D team claims fans are not required in Ather and do cost cutting.
Generally, motor temperature rises fast and disables autohold frequently.
Now when i ride my rizta with pillion rider for 10 kms, the motor heats up and cuts of acceleration for 30 seconds to 1 minute of time.
I need to wait for the throttle response on road managing traffic. Sometimes we need to stop for atleast 1 to 2 mins to get the throttle response. Earlier this problem used to come in February or march months after 15 kms, now it is coming after travelling for 10 kms.
Due to increase in summer temperatures, and the bike is not designed for sustaining our hot summers the throttle keeps cutting of and no response while travelling with pillion rider as it has some more pressure on motor rather than going single person ride.
If this is the case, then what would happen in mid of may month? Why do Ather say, its a family scooter without proper design to ride with pillion rider. If it is for a single person ride then why so it is named as fanily scooter.
Ather should investigate this at the earliest and take necessary action. Recall the scooters and atleast fix a cooling system for motor.
if Ather is not going to take any action on this, i will proceed legally by filing a case in consumer court.
@tarun @swapniljain @smridhi.kalati @rohit.dalvi
Already complained regaridng this in 1st service, they said we will check transmission and later said everything is fine while handing over vehicle back to me.
Today morning when my brother plugged in his Ather rizta 2.9kwh with pro pack, he got an error msg in Ather app saying ‘No load detected by charger’ and the screen on rizta stuck at initialising and the scooter won’t charge !!
Did any one else face the same issue or any one knows how to rectify this ?
TIA
Yesterday night, I fully charged my Ather Rizta Z (2.9 kWh variant). I rode it to my office in the morning without any issues. However, by noon, when I tried to start the scooter, it was completely unresponsive. There was no ignition, the dashboard wouldn’t turn on, and the vehicle was essentially dead. I couldn’t even reboot it.
What’s worse — the scooter is just 10 days old! Is Ather turning into the next Ola? This experience has been extremely disappointing.
Hello, did you receive any response or solution for this issue? I’ve noticed the same problem. Due to the extreme heat in Chennai, the motor tends to overheat, which causes the throttle to be restricted. In Smart Eco mode, the speed doesn’t go beyond 30-35 km/h. I have to switch to Zip mode to achieve higher speeds.
I also feel stiffness of handle seem to be tight i think my scooter is new thats Y but it’s manufacturing problem now i know .
Writing review after 5 months of driving. Highly disapponted with battery performance. Discharge fastly and charge very slowly. It takes almost 12 hours to full charge Many times i had to push physically due to unexpectdely discharge on the way.
Ha ha don’t worry ,you will be ignored like they did to us :smile:
We apex user experience this the most ,we have been complainting since 8 months, no one cares :smile:
Solution *Dont use magic twist .Use real brakes (most imp)
*If your motor is too hot just keep for 5 min then ride
*Check Tyre pressure
*Dont ride aggrasively in hot noon
*Update to latest software if available (To know raise a complaint in app to check for latest version)
Due to handle Razoor kit may be or has to change or handle may be pend or has to tight as i did
Yes but i have tighted the handle nownits ok
Then better purchase a solar panel and charge
It got fixed after 2nd service :blush:
Update: Called the SC in Nungambakkam. They sent engineer. He checked and said their was an update halle ing and because of low network in Ather it was interrupted and the vehicle was dead. He manually plugged in his laptop in Ather and had to upload the update. Took 45mins to 1 hour to completely solve the problem.
Apologies for the delayed update.
I faced this issue also 2 days back. When I turned the key to on position, it did not turn on. Tried multiple times but nothing happened. Then I remembered someone telling in th3 forum to press the start button 3 times and it will boot. Luckily it started. But lots of software bugs like turn indicator not turning on or sometimes not turning off. Screen getting stuck. Reliability factor is very low in the rizta. I am worried if this will become like Ola scooters.
Yes. Reliability is very low. I am.not.gettimg the mentioned range also. On full 100% charge rizta gives only 80-84 km that too only if your drive strictly in smart eco mode. Where as company promised 100-110km. And this indicator problem even I have noticed. Screen stuck problem also happens many times when using maps. Motor heating problem is also there. If I ride with pillion in afternoon the speed does not move more than 35-40. Ather seems to be going ola way.
While Ola is growing in the way of Ather did in their past, and Ather is now growing in the way Ola did.:joy:
After Posting in Twitter they took my vehicle to service centre and they tried riding it. They too got the same issue. They reported it to Ather backend team, and they asked them to ride with turning off magic twist feature. Then there was no issue, so Ather service centre team told me that to turn off magic twist in summers.
That was a comedy reply from Ather team, their replies were like this. Don’t be surprised in future they will also say, In summer dont ride more than 10 kms or dont ride with pillion rider etc.
They are not at all willing to accept their defect instead say vehicle is ok, that is normal behaviour for safety.
Why the hell do i need to turn off magic twist in summer when they keep promoted these things as features during launch and purchase? Why then they have done publicity in the name of family scooter when it doesn’t support riding with pillion rider itself?
They have to install a cooling system for motor kind of fan or atleast air vents then only motor will be cooled by air circulation. Now in rizta it is completely closed without airvents, atleast 450x has air vents so not getting noticed due to air circulation in 450x model
