Theft and Tow was in fact working (w/o the indicator sounds) for a while with a particular build, on a lot of Gen 3s. But yeah, you are right about it being not mentioned there.
Check this
Check this
That 20 min presentation could have been a 5 min teaser. ![]()
I donât know if anyone else noticed but the new 450S has a redesigned mud flap hope thatâs available for others to swap if works well.
Yeah I had the anti theft indicators working on my scooter as well. Donât worry, Iâm confident most of these features will come down to Gen2 as well. Itâs just that theyâre not promising anything cause it might not be ready yet. Now hope they do another event and announce a new Atherstack version asap! ![]()
Oh cool! Then they should be able to push the feature along with sound for existing scooters. I got my 450x 10 days back, still on Atherstack 11.5.6-202324, awaiting the update.
I am now pretty sure this part of the new 450X. If you see the video clearly where they talk about The Bengaluru Button i.e. the hornâŚthey showed the new joystick and other buttons part of the 450x. The 450 S has only the reverse button. That UI was the 450x dash and not 450 S. Also going by specs I personally feel that button i showed is part of the new 450x. But again the question arises that how will the older ones get it?
But Ather being Ather, clearly knows the Art of Surprising its users. So
. Letâs hope for the best (including Gen 2 users like myself)
New mudflap
Mudflap new vala laaye bhi toh jab monsoon khtm hogya tabâ:skull:![]()
Hi @tarun , so you have not Mentioned anything about gen 3 in the key note. Are the previous series of gen 3 are going get retrofit of the new button layouts ? More over are we going to support for updation to the specs ?
So whatâs the update on why they canât push Regen? Itâs obviously not a software issueâŚ
@abhishek.balaji and @tarun are the best person for this question.
@ryan/@sripriya.nellore can you shed some light on why and if ESS as well as coasting regen is backward compatible or not?
Coasting regen isnât backward compatible. It requires regulatory approvals for hardware changes and as this feature involve some changes, it is not coming to older models.
ESS will come as an update to all the versions later.
I donât think regen requires any new hardware. The current 450x has same hardware as gen 3. Only the buttons are new. Yes there may be a button now to activate regen but its like the park assist thing. Even though there is a dedicated button now to trigger it, earlier versions can still use it by pressing brakes + indicator. So it may come to older versions but it may be auto triggered or it may require a different button combination.
Did you read this? Letâs hope Ather can work on getting the required approvals and get us the features asap!
More like software changes, since regen is already available at manual input. Pressing brakes or twisting the trottle in reverse. I think they can implement it via software update, when user let goes of trottle it will get activated.
I was hoping to see some updates regarding the assure subscription, but we got none ![]()
