i have tried to logout and login and also tried to delete the App from my phone and re-install, but no luck
@Shreyas, any pointers to thisā¦ doesnot seem to be a general issue as i have not seen anyone else report this issue.
Hi Ganesh,
There seems to be something off. Would recommend you get in touch with the customer support team and get this checked.
The only reason I can think of this happening is if you shut the vehicle down after every ride. In which case the ride information gets wiped. (that is a known bug, which will be solved in the next update)
@amithsnair, @hemanth.anand, @rajeshkav
For the connector lock case, it is a safety feature and hence we cannot revert to it.
Take this example, in case there is a power cut, the connector would get unlocked, and there is a risk of it partially sliding out. If that happens, and the power comes on, it will start charging without the solenoid being able to lock in place.
Secondly, for users charging with portable cables, anyone can turn off the power and disconnect the cable.
In your case @rajeshkav, if you are able to remove the connector after powering off, then there is reason to believe that your solenoid lock is not functioning properly.
It can be either:
Would recommend you try that again while putting the vehicle on charge when the key is turned on, and then removing the key to start charging. Then turning the podās power off and checking. Please get in touch with the customer support team if it isnāt working as intended.
Itād also be interesting to understand why would some of you want to remove the connector once the charging is complete and not let it be plugged in over-night. (If it is the fan noise issue, that is now solved)
Thatās a good suggestion, Iām not sure if that is something technically possible, in any case you should post it on the OTA Wants thread
Ok Thanks. i shall reach out to the customer support and have it checked.
i can confirm that i have not shut downā¦ infact i am still to get myself to even turn off the motor using the motor kill switch, let alone shutdown. i guess the last shut down was during the update of the 450 SW. May be i should try to do a shutdown once again and see if it would fix the issue and then reach out to customer care.
Now that makes a lot of sense.
When it is charging and if the power is cut down, the solenoid remains intact and the screen remains dark but it is touch responsive. This means that the computer is still on
What will be the discharge rate if it remains on and left over night?
It cannot turn off completely as it has to keep the solenoid intact
Shreyas I have not received the OTA, can it be pushed for my vehicle. Yesterday I called to customer service the response was we
will get back to you.
Your first example makes perfect sense. I experienced it once - the connector had come out. In fact it had come out so much that it wasnāt charging at all! Second example is very true for public charging-I wouldnāt want someone to unplug my scooter.
I canāt speak for others, but let me try to explain my personal preference for the current setup instead of the upcoming setup.
To sum it up, although the current setup suits me well, Iām fine with the future setup as well. Iāll either keep it plugged in overnight or carry Ather key more often than Iām doing now.
Iām eagerly waiting for the updateā¦Especially for the trip meter and reduced brightness. No wonder my favourite song these days is Apna time aayega
may be adding an option (lock solenoid when plugged: on/off) in App or dashboard will solve the problem
as different owners have their own requirement which cannot be consolidated
security is defined by customer at times
In my case, connector was fully in. I am suspecting it is mechanical fault as I am able to take the cable out with Power ON condition (without turning the key on) with hardly any pull pressure. Anyway I did this for testing purpose only to check whether the problem stated has resolved in the current OTA version.
May I know in what battery percentage, fan noise issue is solved? I have checked in between 80 to 100%, fan continues to make same noise. I am of the opinion that in all trickle charging, fan should be turned off unless temp is high.
The charger fan turns off once the current going into the battery pack goes below a certain value.
Since the battery pack charges following a CC-CV curve, itās difficult to predict the exact SoC value, as that can slightly vary.
The bigger advantage is that, once the charging is complete, whenever the vehicle restarts trickle charge, the fan used to kick-in and was an annoyance to people nearby and users who had their pods installed closer to their living space.
Something you had also brought up earlier.
Now, once the charging is near completion, the fan shuts off and doesnāt keep turning on and off through the night
Yup. Can confirm this works now.
I checked it with the team, what Iāve been told is due to the size of this update, itās taking longer to download and install. And for now, waiting is the only way.
I have passed on the suggestions of download indicator and manual download to the team. That is something we will look at, for the subsequent releases.
Thatās goodā¦ I hardly leave it for overnight charging.
A lot of phones have requirements to meet before an update starts downloading. For instance, phone has to be plugged in, battery above 50% and network above 50% will trigger the download. Maybe something like this can be done?
Auto trigger the update when a vehicle is plugged into a fast charger and has >30-50% charge. A manual trigger option would probably get rate limited when you have more vehicles on the road.
Itās already there AFAIK. Download happens only when the scooter is charging or in use (I assume above 10km range left) with strong 3G signals.
Yeah, itās too uncertain right now. We need more info on what triggers the update, so we can try. If itās left ambiguous, itās possible that it downloads, but we never know, cos it was not intended. I suspect my dash is never on for long enough for this large update to download. Possibly download getting cut off when I shut down the vehicle.
I noticed it last night that even at 100% charge(I had put it on charge for over 5 hours) the fan was ON when I went to plug it out. Not sure if what you claim is actually happening.
A pleasant surprise today morningā¦wanted to go for a haircut and switched on the 450. First screen I saw was the black āyour software is updatedā. A lucky start to the day that continued till the hair salon where I didnāt have to wait at all
Anyway, happy that finally the scooter firmware is updated after a long wait!
Just took delivery of my new 450! Just wondering if the software is upto date. The version is 2.0.0.514149 ( shown on the app).
If this is the latest then I am unable to see the save work/ home feature on either the app or the dashboard.
Am I missing something?
