This is a great update. But still missing the requirement of finding out how many km we actually got for the full charge. It would be great if we another counter which records the actual km we got between charges. Is this planned for a new trip meter?
In ride statistics, you can see the time and distance for every trip you made…
i would like to request to add reflective white paint in rear Ather branding.
so that it is clearly visible.
-Saadmanna
I feel break leavers are low in quality, i had even mentioned it during my test drive.
i saw one broken lever today. if you can get the quality of Vespa Scooter Levers that will be great.
-Saadmanna
Well wait is over
it just got approved and you should be able to see update for iOS now on your devices now
Got the app update on iOS! Although I am not able to see ride history yet, does it take much time to sync and retrieve that data?
One more funny observation I have is how the projected range on SPORT mode is higher than that in RIDE mode still. I never use RIDE mode but I don’t think that should stop the algorithm from making a calculated guess which should be higher than the projected range in SPORT mode. Is this a known bug @subramanian.g?
Hello Everyone!
We are planning a series of How-to-videos. These bunch of videos will help new owners make the best use of their Ather vehicles.
Feel free to share your suggestions here.
Thank you!
Still not able to see my ride from this morning on the ride statistics tab. Is anyone else using the iOS app facing this issue?
@Shreyas I am facing the same issue @samitbanerji is facing. No ride updates in the IOS App.
Talked to Sahil at customer support. He told me he should be able to provide a solution by EOD.
Mine took a day or two to sync. And ride stats for any ride seem to be delayed by half a day or so.
are you using the iOS app too? The update came out yesterday evening only for iOS. My ride from this morning has not synced yet. So ride statistics is still blank asking me to take my first ride. I tried the shutdown procedure once as suggested by Sahil from Ather but even that did not help.
Usvally for me it sync with in half an hour most of the time.
That is not enough. I am not sure how many trips will be shown in the ride statistics. Sitting and calculating is a lot of manual work. It would be ideal to have a trip meter which will not get reset when the vehicle is switched off.
Agreed with your point
Finally got statistics of my second ride this evening post the app update.
Since start/end points are not accurate which is understandable given the limitations of GPS, one way to improve this could be either to have an option of editing these points, or just have the name of the area of the two ends of the trip, would probably make more sense.
Hello @sudhanva.atri,
Appreciate your idea in making how-to-videos
I am expecting video about how to increase the range and correct use of Regen in the vehicle
Thanks
How to clean the vents of the vehicle?
It’s still not working for me
