Yes, if you maintain a speed of 20-25kmph. You can get 100+ km range comfortably. Even at 30kmph you can get 90-100Km range. Is it practical for you to be riding at 20-25kmph? That’s for you to decide.
Absolutely in our busy life every minute is precious in my case i would rather drive at 60kmph and charge whenever required. The issue is i dont have patience level to drive at 20 to 25kmph and after switching to ev one new stress i have found is more than driving i keep looking at dashboard to check range and speed.
Overall its been 1plus month and i have been using 450x for all my daily commute , what I understand is if round trip is around 30km then 450x does the job no matter what the weight if both rider and pillion and any road.
The most positive side for me is cost cut if i calculate fuel cost for 719km then
Ktm duke 390 - 25km mileage Fuel required - 719/25 = 28.76 litres Shell petrol cost = 28.76×94 = 2703
So in a month time i am able to save so much if i continue to use the ather 450x for atleast2 years then whatever money invested is returned for me.
Check out this thread Savings
Excellent info…Thanks @saranyam.13891
Recently I purchased Ather 450 X series 1.
After going through this blog, today I gave a test on Sports mode.
Before the ride
Odo Meter: 1216 kms, Mode: Sport, Projected Range: 38 Kms, Battery: 64%
After the ride
Odo Meter: 1241 kms, Mode: Sport, Projected Range: 25 Kms, Battery: 41%
I actually travelled 25 kms (1241-1216 = 25) Difference in projected Range 13 Kms(38-25) Difference in Battery % is 23%
The cruising speed was 40-60 kmph.
The dashboard shown sports mode with 64% battery and projected range is 38kms. so 100% battery in sports mode shows 60kms
However, the real stats are much better than dashboard stats. Its actually double.
so to conclude, 100% battery definitely supports more than 100kms when cruising 40-60 kmph on Sports Mode
Sensible suggestions… Would love to test them on my series 1… So far I ve been getting the range around 80 kms for single charge…thanks for post
It’s a common misunderstanding, The rating you are seeing on the dashboard is the Trip B which will show the current Trip B analysis, which until you reset it will calculate accordingly.
While your app in the phone actually calculates according to when you started the ride and ended it, it calculated for one single ride
I reseted the trip meter B after charged… then took those rides…
There is a difference in value between app ride stats and dashboard ride stats. Many feel app ride stats are more accurate than dashboard.
yes after you reset it the analysis is for the entire 23.3 KM according to your dashboard, while the app calculates the ride in, from when the key was turned on till when the key was turned off, so you will get most of the actual projected range according to your app. while in trip meter it will not calculate. In short app calculations are better than the trip readings
I thinks it’s the other way, like @abhishek.balaji said,
Efficiency is when we have better range!?![]()
Efficiency is Directly proportional to Range. Correct me.
Actually, both of the statements are same! When the efficiency is less, it gives more range. When max throttle is applied, more battery is used, hence, more efficiency and less range. Both are inversely proportional.
How I understood is, when it’s not giving good range, it’s simply not efficient.
Btw, what happens when we release the throttle not accelerating nor regen while we are already at a certain speed?
See, in literal sense, you may see efficiency as a measure of being efficient. In case of EVs, it is the Wh (Watt-Hour) consuned per Kilometer. Hence, lower the Wh consumed, better is the efficiency. Also, better efficiency leads to a better range.
When no brakes (also regen) are applied and the motor is still in motion, it simply consumes the battery! As simple as that!
Are we sure that motor still consumes power when not accelerating. Don’t think so. If motor consumes power, then what if you only switch on motor and not moving the vehicle, still that consumes the power from battery. May be Yes, because it needs to maintain the vehicle status thus consuming low power for required things.
Actually No. The moment you take your hand off the throttle, power delivery to the motor is stopped.
Oh ok. You are Right. Thanks. I’d put this as, 'Efficiency in EV’s ’ is, Good range consuming least power.
More Kms with less Wh. And that’s More efficient now. Correct me
So,
It’s, “Efficiency is Directly proportional to Range, and inversely proportional to Power Consumption.”
More efficient driving = More range
More efficient riding = Low consumption = Low Wh/Km rating.
But still 80 in dashboard and 40 in app is a vast difference…!!
