just consumed a little more battery for me!
what is the ideal efficiency (from RideStats) to be maintained in order to increase range?
I am just getting 55-60kms
30-35 wh/km
Itâs actually quite easy to get more than 60-70kms projected range in the Ride Stats in Sports mode. I usually ride in sports mode. Very rarely use the Ride mode. The sports mode is a lot of fun. Iâm not always zipping about, but I do like the flexibility of having to zip if necessary.
I think it all depends on how you accelerate.
Something Iâve noticed while riding is, that you should accelerate slowly, because at lower speeds, the vehicle needs more torque to move, so twisting the throttle fast from rest or low speeds will use up a lot of battery. But, at higher speeds, itâs easier to maintain/go faster because less torque is needed. So climbing from 30 to 60 uses less battery than 0-30.
Also try and use the inertia of the vehicle in motion to carry you forward, instead of sudden acceleration and braking.
Iâve ridden at speeds of about 80kmph on the ring road stretch and I still get a projected range of about 80kms in Sports mode (in Ride Stats). I also use good amounts of Regen to slow down whenever possible, and then use brakes to come to a halt.
My efficiency is usually around 28-34Wh/km
Avoid sudden acceleration and braking. Maintain average speed around 40-50. Ride mode is ideal for this kind of efficiency. However on free roads sports mode will also be efficient.
@Ather.Team Achieved 1000km mark todayâŚWay to go further
From past 2 days facing screen reboot issueâŚSuddenly it reboots while moving (3times happened), when I switch on the key screen doesnât show up, it takes lot of time âŚFew times need to take the key out but still screen in one mode with dark background nothing showingâŚAnyhow hope these bugs will be solved in next OTA
Thanks,
Arvind
Screen hung up while riding.
Vehicle was working but screen wasnât showing any of the information like vehicle on and off, maps, indicator, etc.
In a different incident, Vehicle once did not start even though it was in on position. The screen was also blank at that point and suddenly it rebooted automatically and vehicle came to a normal.
@Shreyas kindly find the bugs related to these issues.
For such issues, pls call support and log an issue.
It was a one off
If it repeats surely will contact customer support.
I donât know if this is a correct observation, but I feel that toggling between Ride and Sports mode is more efficient than sticking to Ride mode always. Sports Mode at 60kmph is more efficient than Ride Mode at 60kmph.
Efficiency does not depend on speed alone. Gradient/braking/use of regen/acceleration/quality of roads/temperature all contribute to it.
I got your pointâŚlike pushing the vehicle to 60+kmph in ride mode vs 60+kmph in sportsâŚI also feel the vehicle struggling a bit when we cross 60kmph in ride modeâŚnot sure of how itâs affecting the efficiencyâŚnever tested it on roadâŚ
Max speed is capped in ride mode. Thatâs why you feel it struggle
@Ather.Team I noticed some issue yesterday. Let me know if anyone has felt/reported similar issue.
Just after powering up the scooter accelerating bike was frozen for a 1 sec, later move reverse little bit after few seconds it was normal.
I have felt earlier also, but was not sure issue then.
(parks assist was not active)
Saad
Check if the accelerator handle is getting stuck⌠I had this problem in activa where even after releasing the handle the vehicle continued to accelerate and got me into a minor accidentâŚ
Link of similar issue
I have seen just now ather in Kaggadasapura⌠vehicle no ending with 5122. Anyone staying near by?
+1 . I am also staying in Kaggadaspura. my vehicle no 0445.
Regards,
Ravi kanth
Great then⌠what was you order ID?
