450 It is a good experience if you need my detail opinion I have DM you can have a talk
Thanks for the reply. I just wanted to know how the EV performance is at uphill roads.
It is quite good actually! They have tested the vehicle extensively on steep slopes to ensure that it performs very well.
On par with 125cc scooters
I disagree. It outperforms ICE scooters uphill hands down
The 450âs sport mode is almost on par with say⌠Ntorq125.
Only exception I guess
Will there be any issues if both the tyres are filled to 32PSI with nitrogen?
If youâre riding with a pillion. Not an issue. If you donât. Then just be careful and donât lock up your rear wheels. Your efficiency will even be a tad bit better.
ThanksâŚI did not get the relationship between air pressure and locking up of rear wheel. If possible share your views.
Well basically when you overinflate a tyre. Itâll tend to have less traction. Because less of the tyre is actually in contact with the tarmac. Same reason why you reduce the pressure in tyres which are going to be taken off-road like on sand, to increase traction. And since contact is a bit lower, the efficiency will be a tad bit better.
2 posts were merged into an existing topic: Mileage Archives
In the last few months, i hardly used shut-down may be zero in last 2-3 months. Yesterday, I used shut-down because I had a need and SOC was 63%.
When I started the vehicle back around 10 hours later, I noticed it was 5% down. If I remember right, the drain rate with shut-down was 1-2% overnight. Can some one confirm that please?
Maybe cold climate affect battery degradation.
No, I remember using shut down for many months including winter seasons and the drain was very low during shutdown. If anyone else can confirm, that will help me to see if I need to report to customer care.
A post was merged into an existing topic: Service related issues
Hey ather owners. I wanted to know who here on the forum has the highest ODO reading. Iâm assuming itâll mostly be the 2018 owners or maybe even some 2019 owners. If youâve riden over 25k Km do post here, I think a lot of us would love to know. Anyone clocked 30k yet? @abhishek.balaji maybe you can disclose the numbers ? Or maybe it already is disclosed ? No need to know who but could you tell us how many Km ? @Abhishek youâve done over 25 k right?
Canât share othersâ data, but would love to hear from owners whoâve clocked more than 20k or even 25k kms.
A post was merged into an existing topic: Order Swapping
