26-Feb: Vehicle registration
06-Mar: Took Delivery
18-Mar: Received RC via Speed post
Got my RC without any hassles
Me too got it yesterday
I have not yet received. Delivered on February 29th. Did you get tracking number in sms or just delivered?
Just delivered directly
For loan or outright purchase cases, Itâll be delivered by Post by RTO. No tracking will be provided
OK Thanks. Mine is full payment and will wait for few days to get it delivered. @josephsahayaraj @hemanth.anand
Can I directly top up with nitrogen or should I deflate completely and refill with nitrogen
Please deflate both the tyres and then fill it up with nitrogen. I did the same for my 450.
I observed that tyres lost 8PSI in a span of 9 daysâŠguess something is wrong. I ride only 19.5km per day.
What is nitrogen pressure setup for each tires ?
Back ? Front ? Pls share details
OK. Thanks. I was in impression that tyres were with nitrogen at the time of delivery⊠Any one can confirmâŠ
Recommended to deflate and inflate again. But even otherwise, no issue. Nitrogen from the dispensers are 95% Nitrogen. Normal air contains 78% Nitrogen.
If you had searched once, youâd have got the answer to this. People have found solutions to this in 2 different ways. 1: Change air valve to the straight one 2: Change the tyre.
Nitrogen or otherwise, go to settings and press the i button on the scooterâs dash and itâll display the recommended pressure
No. Normal air.
Same here they called up and applied 3m uv film. Application could have been better
Iâd noticed this pressure loss earlier too. But thatâs when I used to fill air at the petrol bunk, so I couldnât check if the issue was with the pump or the tire. Now I have a manual pump ( #socialdistancingbeforecorona ) and the air reduces only by about 2psi in 2-3 weeks.
But Iâd also given the vehicle for service in between, so canât tell if the issue was fixed during service. Either way, I find it a lot more reliable and easier to use my own air pump:
Michelin 12206 Analogue Double Barrel Foot Pump (Black) https://www.amazon.in/dp/B00IOQ1LR8/ref=cm_sw_r_other_apa_i_FOeDEbJDXPFPT
I have observed that there are small cracks in the tires between the creases. Is it normal?
Can you post pics so that weâll have an idea how small the cracks are?
Looks normal to me, but I would defer advice from an expert here.
Driven more on rough roadsâŠunsurfaced roads
