“Is Nitrogen Right For Me?”
For normal everyday consumer tire service applications, nitrogen tire inflation is not required.
However, nitrogen tire inflation does not harm tires and may marginally contribute to reductions in tire inflation loss by permeation. Nevertheless, nitrogen will not prevent any tire inflation loss caused by punctures, tire/rim interface (bead) leaks, valve leaks, valve/rim interface leaks, wheel leaks, and other mechanical leaks. Again, the use of nitrogen alone does not substitute for the importance of regularly checking tire inflation pressure. If the tire inflation pressure is below the pressure specified on the vehicle placard, the tire must be re-inflated – whether with air or nitrogen – to the proper inflation pressure. Do not operate tires underinflated and/or overloaded (see your vehicle owner’s manual for tire inflation and max load recommendations)."
You can read the complete article at https://www.continentaltire.com/news/nitrogen-vs-air-what-right-my-tire
