Ownership Experience
This is the range remaining based on your current battery capacity, for the true range. So for Ride, it’ll display out of
Eco - 75km Ride - 65km Sport - 55km
Predicted range is calculated based on your past history of rides. As you ride more in each of the modes, this number will change based on your driving patterns. It’s an indicator of how your driving style is and how much range you can expect based on the driving style.
The projected range is displayed per ride. It’s an indicator of how much range you can expect out of a full charge if you ride the same way as per the ride.
For instance, in your latest ride, your project range is 79km in Ride mode. If you drive with a similar riding style as this ride, you’re likely to get 79km out of a single charge in Ride mode. Which means, your driving style is better than the True Range :slight_smile:
