What about the other vehicle features, if someone who is using my vehicle changed it, I might not be noted of it…
Heads up for all. TPMS feature will be enabled on Rizta along with next AS6 update. Its not working as of now.
https://forum.atherenergy.com/t/tpms-on-rizta/291034/16?u=marghoob.hasanWhen will get the update of ping my scooter and theft alert
These are also expected in Sept’24
Mine is 3 weeks old. I’m facing this same issue from day1. Never ever did I get a range nearing 100km. I ride roughly 10kms a day. Includin interday idle drainage, the overall range i get is near about 85+
Try shutdown option during night to avoid idle drainage issue. In my experience longer distance you travel more possibility of saving battery. The reason for it is more possibility of using magic twist and coastal regen hence battery get recharges. In short distance travel it is consuming minimum 1 percentage for 1 km if you drive with pillion. I am able to get 125 in eco mode and I travel every day 30 km. I barely use break instead use magic twist but my average speed is 40km/hr. Also check app for how many efficient ride you had so far that will give you some idea.
Even after riding very conservatively in Smart eco mode using coasting regen and magic twist not getting more than 900m per 1% of charge.
Did you check it with the service centre? Do let me know updates
It’s same for me. Not getting more than 85kms even in smart eco mode. I think need to get the tension of belt checked and adjusted.
The post you have mentioned is a very old post. The title mentions Ather 450 which was Gen 1 Ather. From 450X Gen 2, there is no issue with shutting down daily.
I own Rizta 3.7kwh and easily get 115 -120 kms on 100% battery.
@smridhi.kalati Hi, still I didn’t received the update on vehicle. TPMS installed but unable to use because of update.
This is old post and even in that post last they have mentioned BMS tuned now handle shut down properly. Even other post I saw even SC suggesting shut down as option for idle drainage issue. For safer side you use shut down feature after 80%
Is ur bluetooth enabled ? Call and Music controls are already enabled with recent AS6 update ( 30.6.00-202432). Check your AS6 version.
Any 1 facing reverse issue post update reverse is not working and call notification is not working need to manually switch off and on Bluetooth
In my experience last four weeks with Ather Rizta what I observed is first 100 to 90 % baterry drain pretty fast more than 1% per KM. This atleast make sense as coasting regen will not trigger. But I am not able to understand why 20 to 0% also drain very very fast. Sometimes it is 2% drainage per KM. I am able to get maximum range in 90% to 20%. Also after latest update sometimes I feel even even though vehicle is running smart eco mode it operates like Zip mode. Whether others also facing this issue?
August today is the last day of the month, still I didn’t received the update (Bluetooth) wow Ather nice to see the promises which can’t make any difference…
Dear friends
Suddenly today bluetooth not connect to rizta. Any issues
Any one facing the error
Any updates for Atherstack 6 Ather Ritza .Battery is getting draining 2KM without using and current Ride and vechile display KM is not matching , when I cross check , is there any solution for the battery suddenly drain 2 KM. Please recommend the solution for the issue.
Ather already has Atherstack 6. AS6 update was also pushed to many Riztas in Aug last week which enabled Bluetooth.
