Hazard lights
Ather Team Please consider Hazard light functionality vie OTA update
heard somewhere that hazard light switch needs to be a physical different switch to be legally integrated
Hazard lights shouldn’t be used while driving, this is the rule in India. If at all you want to warn other drivers if you have stopped at a dangerous place, simply turn on the reverse mode, it will flash both the indicators and act like an ad-hoc hazard light.
Thanks for tip :slight_smile:
In case of emergency brake Ather has implemented ess , emergency stop signal u can see the videos on how it indicates. On YTâ˜ș
we can not use this function when vehicle is on stand :confused:
I see this stupidity only in Bangalore. People here turn on hazard lights in the lightest of a rain and drive at high speeds on the highways.
Irony part is im from Bangalore and people requesting this aren’t from Bangalore :rofl::joy:
Ather Rizta already have hazard lights like feature - when doing reverse. Also ping my scooter - also have same thing. So technically its there. In many city (including mine - Agartala) we use this all indicator on - to tell people that I go straight in a 4 way crossing. This is a must thing for every vehicle. Ather should give us this - for rizta at-least (as its a family scooter - as advertised).
As I heard from someone, You need Physical Key for Hazard Lights in the Vehicle otherwise not possible
So Noo for Rizta and 450 as of now
What if we click ping my scooter and drive along will the hazard lights work??
Key needs to be turned off to access PMS
