I am planning to not bother talking to my owner at all regarding power socket request or Ather DOT installation. I am quite sure it will not go my way or the way of logic.
My plan now is to drop a wire from third floor to the parking basement. I have a straight line of view with very less obstacles. I am hoping 16 mtrs of wire is sufficient (assuming 4mtrs per floor length plus additional 4 mtrs for buffer).
Please suggest if there is any special wiring i need to purchase. My plan now is to buy 20 mtrs normal PVC wire.
Whether i should get 2 core or 3 core wire and does it matter?. Also understand that the thickness of the wire varies starting from 0.50 sqmm and higher. Any recommendation for this as well.
One end of the wire will connect to a 5A plug to fit into nearest socket at my main door. The other end of the wire with a 15A socket (or 5A socket will do?). The Ather portable charger will go into this 15A socket. Is this plan okay?
Please advice. Thank you.
