BYO(H)=Bring your own (helmet)
@abhishek.balaji Can we buy from Bangalore center at the time of delivery?
I understood that from context, interesting usage of the BYOB abbreviation
Motoroids: Mavox Introduces Bluetooth-enabled Helmets At A Starting Price Of INR 999.
Hope some might be interested
Bumping the question - can we buy helmets from Ather at the time of delivery - Bangalore
There were a couple of options provided some days ago. It must still be there. They were Vega helmets IIRC. Owners also had optio of buying them in a couple of user meets. Eitherways Iād suggest you buy it outside or online where you get many more options.
Thanks, will take my own helmet to be on the safer side
i saw a mavox box at ather openhouse in chennai. they are probably collabrating with this brand for the connected helmet.
Not everything is a clue
The current helmets provided with your purchase in Chennai are from Mavox
That was quick Abhishek
What are you trying to hide ::Tin foil hat::
I was wondering⦠If I were to put a PRESS sticker on the back, where would it fit without facing downwards or upwards? The front seems sorted, the mudguard or the small black plastic panel on the handlebar would work. The back is what Iām a little concerned about.
You can cover the area at the rear where there is ATHER written on the black plastic. You can use some kind of thick sheet or fibre plastic (number plate material) for this.then you can paste PRESS or whatever you want.
Interesting, but Ather will get covered up right? Never mind, interesting option. Iāll definitely look into it. Thanks!
But ATHER is not as influential as PRESS right?
Actually I wanted to write something elseā¦some fun phase in the rear of the scooter. This was the only place at the rear which is vertical. Rest all other areas either point down or up as you wrote. So I ditched my idea.
Right, youāve got a point. Thatās something Iāll definitely consider.
Request Ather to come up with a nice cover (as genuine accessory) for the scooter.
Address and cost
Pap⦠aur kya kya design solution dega @Ather.Teamā¦
Itās proven that people will lose their life if they donāt wear helmets. How many purchase and wear?
I hope you posted this in a lighter vein! Otherwise, I donāt know what to sayā¦
On a personal note, this is likely caused by badly fitting helmets, and usage for long durations. Make sure to get a helmet that fits you correctly, and clean it regularly.
