Please raise it as a ticket via the app. Faster resolution that way. Just posting what Abhishek is likely to post as wellđ
Hey guys, Can the charger be removed from the charging point after 100% with out the key. I ask this because I had kept my ather 450plus for charge at the Indiranagar ather grid next to the store and walked back home. When I went back to pick it up someone had removed my charger and placed it back on the holder. Does it unlock after 100% , I am a little worried if it doesnât unlock and people force pull out the charger it would damage the vehicle. I am assuming someone check the charge saw it was 100% and pulled it out and places it back on the ather grid holder.
New update is here to unlock at 100% to prevent hogging of the charger. Once 100%, charger unlocks. Works on X and + as of now.
Haha, charge thirsty good samaritans on the grid sharing thread are worried about grid supercharger points getting hogged and pushing their scooty home, and here we have someone whose home is a walkâs distance away, and is more worried about his scooty port getting damaged even after letting it sit there after reaching 100% charge. I really wonder what sort of emergency you had there man.
Please donât take over the point, just cus itâs free doesnât mean you have to abuse it.
Ah, how can we conclude so fast that itâs abuse? Maybe the poor dude was in a hurry to go someplace important and forgot to charge his scooty at home?
Ya I needed to charge it quick, how is it abuse ? It was not used and itâs close to home(thatâs an advantage I have). And itâs a genuine worry of damage guys I dont mind people pulling out the charge as long as it doesnât damage the vehicle.
Btw I let it sit there just 15 minutes out. Not hours together. Jeez didnât think people would get toxic here, if it doesnât damage the port o am fine with it.
Letâs take it easy folks. Not everyone is aware of queuing problems at Ather Grid points.
@konerirajb please take care when using fast charging grids and ensure youâre around when the session is on. This is to ensure that owners who have a more critical need can charge up.
Tonight I went to forum mall Chennai and I charged immediately at the grid (at 8.07) once I entered.
I came back at 8:57 and it was charged only 45%.When I plugged in the charge was around 35% , as Ather if it was charged at 1.5km/min it should have charged atleast till 70%.
Is there any issue with my 450x or with the grid.
Anyone from @Chennai facing same problem like this ?
hello. What was the temperature. Cool temperature decrease the charging current, so it in creases the time to charge⌠Loic
Donât know how to find the temperature ?
He means local temperature. @loic.trocme itâs Chennai. Iâm sure, cold weather isnât the issue here. No matter the temperature. This speed of charging is mighty slow. Itâs probably a grid point issue and not a scooter issue. Report it and ather will fix it up.
If Iâve charging on grid, can anyone else disconnect the flight when 100%/80% charged?
450X or 450Plus yes after 100%.
450 no as of now but, an OTA is announced for this feature (no time line yet)
Sarath City capital (Hyderabad) Mallâs grid charger is turned off till 11am and not turned on even upon requesting. Please change the timings in Ather Grid app accordingly @abhishek.balaji. Thank you !
Chaitanya Pothapragada Date: 21-02-2021
Hi every one,
I want to share my experience at Ather grid point that happened to me. I went to the nearest grid point for charging my Ather and I found that already one of the other customerâs ather using it. when I checked his status of his charging ather was fully charged 100% and I stand there for a half-hour no response from that customer. I request AtherEnergy to make a solution for this type of issue at grid points.
were you not able to pull the plug back? I thought @ather-bubhandari had done a necessary update after 4.3 that would allow to pull the plug once reaching 100% charge.
Is the other vehicle 450 or 450plus or 450x.
Incase of 450 an update is under works but in case of 450plus and 450x you can unplug the charger once it reaches 100% this feature is enabled out of the box itself.
I have offered a commercial space for ather grid charging point. No one has reverted on tis to me.
Most of the time Ather grid Charging point at Sangeetha Mobile near Chandra Layout is shown as unavailable in the ather grid app. Is the point working or is it use ?
