Hey folks!
We’re rolling out an OTA update with a few new features, improvements and bug fixes. This update will be rolled out in phases over the next few weeks and should get downloaded on your scooter.
There are two key new features:
Optimized Charging 2.0
With an EV, there’s constant worry about prolonging the life of the battery. A quick Google search points to a bunch of advice that’s more confusing and worrying than helpful. We introduced Optimised Charging earlier, which cuts off charging at 80% so you don’t have to manually unplug or decide between lower range and longer battery life.
We’re introducing a significant change with Optimised Charging 2.0.
When plugged in overnight, the scooter intelligently pauses and restarts charging for you, to ensure you wake up to a full charge.
Optimised Charging 2.0 will be available to all owners Gen 2 and above, and will be rolled out as an OTA update in phases.
The Optimised Charging feature enhances battery life and provides convenience by ensuring the scooter is fully charged by 5:00 AM in the morning.
After the update, this feature will be triggered if charging sessions start between 6:00 PM to 1:00 AM. The scooter will reach 100% SOC by the next morning at 5 AM.
You will have the option to enable/disable this feature for the current charging session on the charger-detected screen. You can visit settings on HMI, and use the “Optimised Charging” button to set the default ON or OFF state of the feature.
Note: The option on the charging screen will be reset to the option selected on the settings for every charging session. If you enable or disable the feature on the charger detected screen, it will be applicable only for the current charging session.
Regen indicator on dashboard
While coasting regen is possible only on the new 450 series, the 450X, Plus and 450X with Pro Pack have had active regen since the start. Active regen can be activated either by twisting the throttle in the opposite direction or when applying brakes. Active regen helps recover upto 4% of charge when used aggressively.
We’re now improving this experience by adding an indicator on the wings of power when active regen is being used.
