Just received Ather Stack 5.10 11.5.10-202346 which was pushed out to people who have signed up on [Beta testing for Dashboard Navigation] thread
New Features/Offcial Changelog:
Live-Traffic
Introducing live traffic on the route while navigating, just as you see on your smartphone.
Our Google-powered onboard navigation now suggests 2-wheeler-specific routes for the first time on a scooter, improving navigation and ETA accuracy.
Improved location accuracy
We have improved the location accuracy by using Assisted GPS (AGPS), which will make the navigation response faster and smoother.
Note: Location-sharing permission is required
To use AGPS, the Android operating system requires you to grant
location-sharing permission on HML A pop-up will appear on the screen when you use navigation. Please tap “Agree” to enable AGPS.
Fall Safe
If the scooter falls off, this feature cuts off the power supply to the motor and helps you pick it up safely. As an additional safety layer, both the indicators also start blinking, to alert fellow riders on the road.
Flashing Alerts
Theft and Tow detection will now alert the bystanders with sound alarms and blinking indicator lights, triggered by unauthorized movement of the scooter. This also works with your Park assist to indicate that the scooter is driving in reverse mode.
So far the dashboard is running really smooth but I was hoping more navigation features (grid chargers on map like in stack 5.1 or destination reached notification).Theft alert detection seems lowered than before and isn’t sending notification which was working on 5.9.Charging done notification,fall safe have’t been tested.I have heard few reports of TPMS still bit messed up.Overall big update bringing all new features from gen 4 to 3 except ESS.
I have doubts regarding the flash alerts if triggered accidentally, how should it be turned off , the owner should turn on the key or any specific time after which it turns off automatically?? @smridhi.kalati
Towing and Theft detection is working. For Fall safe, I tried lying the vehicle down completely with the ignition on but it was live. I did not venture to test it as in real fall though
Why can’t they keep hazards light on in Park Assist FORWARD as well? Why only reverse?
In FORWARD also we are a hazard since we are only limited to 5km/h. Hazard lights should remain on in the entirety of Park Assist and definitely should have a provision to keep them on with the sidestand deployed.
