Ather Rizta | From our family to yours
Mainly because Rizta is 32% less powerful than 450x and 20% less powerful than 450S too.
Rizta has peak power of only 4.3 kW and coupled with gentler throttle calibration (it hits 40kph in 4.7 seconds only), it would have more range than previous Ather models inspite of being heavier.
Can I exchange my Ather 450x with Rizta?
What is the haptics that you guys are talking about?
No, you can’t.
There is an experiment happening where if you switch to reverse mode, the scooter will mild keep nudging to the back (or to the front) so that the rider doesn’t need to look at the screen to identify if they’ll be going back or forward on applying acceleration.
The vehicle doesn’t actually move. During the demonstration due to surface of the pedestal and it’s placement it was moving.
Only for Z HR variant
@tarun Said at 50:18 seconds into the Rizta Launch Day Keynote that Rizta will ship only with Ather Duo.
He left of the part where it will ship only the HR Z MODEL, alot of things where not communicated. Like it won’t have touchscreen. The picture is the spec sheet.
It’s funny, EV makers are the ones who create hurdles in EV adoption. 350W charger :face_exhaling:
2nd question that I get from people is how long it takes to charge and imagine explaining that it will take 8.5 hours.
My gaming laptop comes with 250w charger. And that is for a such a small battery. I can never justify 350w charger for an EV that will cost upwards of 1lack.
(Updated) Most of the Rizta and 450X, 450S Differences I could find…
Rizta Downers
No Touchscreen in TFT Display of Z Variants
Peak Power only 4.3kW | 5.4 kW in 450S, 6.4kW in 450X
Top Speed 80kph | 90kph in 450S and 450X
15° Gradeability | 18° in 450S, 20° in 450X
Slower Acceleration 0-40 in 4.7s(Zip) | 450X 3.3s(Warp), 450S 3.9s(Sport)
Steel Tubular Rear Subframe
Single Piston Front Disc Brake (compared to Three Piston Bybre Caliper of 450 series)
Rear Drum Brake
165mm Ground Clearance
Kerb Weight 119kg
Rizta Positives
Longer Range
400mm Water Wading Capability
More Spacious Floorboard
Wider and Longer Seat
Pillion Backrest in Z variants
Magic Twist
Skid Traction Control
Larger Boot Space 34L
Belt Cover
100 Section Rear Tyre even on Rizta S variant
Ather Duo Charger 700W in Rizta Z 3.7kWh variant
22L Frunk Accessory Option
Boot Multipurpose Charger Option
Boot Organizer Bag Option
Yes in 2024 for an EV it’s very slow charging!
Atleast the portable charger option for S and Z LR variants could’ve been 700W and the Duo Charger atleast 900-1200W
Ather duo is 750w right?
Aluminium frame also compromised…
I think it’s okay. Single mold aluminium frame is expensive.
what was promoted as USP in 450X is now compromised in Rizta…
As per the website it is 700w
They say in email that you get skid control, Google maps, magic twist are included in the base price. But the website says you need to buy pro pack.
That tiny * near it, would refer that it will required to purchase the pro-pack.
