Ather Rizta design Issues
Today I have face an issue with my rizta 2.9 is after charged at grid I turned on key and scooter not on instantly and takes around 30sec to turn on… any one faced this issue and can you tell Me the exact issue with scooter at that point…
Haven’t faced this issue however my rizta got rebooted twice while riding. Good thing was the power to the motor was not cutoff for a single second.
The lighting on our country’s roads is quite insufficient. Driving at a speed of 50 or more at night becomes difficult. If there is a pothole a short distance ahead, you wouldn’t even notice it.
country roads we can’t change. but we have option to give good lighting scope to our scooters. Rizta lighting is not sufficient to ride at night speed with 50 above… nighttime drive at speed of 30-35kms because of headlight range and visibility while we are driving in single road… opposite vehicle light making rizta light to zero visibility…
Faced the same issue. Got an auxiliary light connected . Now i have more than enough llight to drive in the dark roads
That key hole issue is an issue in all Ather’s not just rizta . Is there in 450s as well
Is it okay if we stick it with feviquick or something😅
Front doom panal is making sounds any one with this issue… and get resolution
Even the Auto Hold has issues, like it isn’t strong enough to hold the vehicle on slopes. Also, on some slopes, the vehicle just refuses to engage autohold.
Yes once I removed the wrapper it started giving sound.
I have the same issue, I made a video and posted in Twitter and Ather replied back and informed their design team is aware of this and as of now there is no solution. The new batch i have noticed floor board fitting is fine. They should recall the faulty batch and replace the floor board.
Same issue :raised_back_of_hand:
Rizta Friction Issues in handle Bar:
Handle bar and front tyre friction issue - looks like I received an old used Rizta vehicle :slightly_frowning_face:. It was the first batch delivery at Kochi Aluva showroom.
Handle bar gets glued most time when riding, turning left/right giving pain in arms due to the friction.
While in auto brighteness , the lowest brightness in night is not the the lowest of manual settings. Which makes difficult to drive, as there is no night mode
Please bring dark mode for Ather rizta :pray: :pray: :pray:
anyone getting sound o front doom upper panel… mine is very noisy and disturbance while driving in smooth roads also…
I got app update on Ios today afternoon but not change in app lags and sync issues/
Front handle visor is loose, and noisy while driving
I started facing the noise after I removed the wrapper. I did not face untill wrapper is on. Looks like design issue with rizta. I am not sure how they will fix. It should be same for all the rizta models
Rizta software is not good and unable to track scooter sync 42 mins ago. if scooter theft, how can we track in real-time… GPS and app sync is worst… anyone with this issue
