Gold digger service center
Another thing I noticed only till 80% battery can be charged by magic twist in steep downhill I downrun 23 kilometer only motor could maximum charge till 80% more than that it couldnāt charge It will not decrease from 80% or increase from 80% in a down hill it stay at 80% After sometime continuosly using magic twist Normal regen wonāt work in downhill it will be very weak at ,80% battery -In apex-
Also if you lube the both belt with greese (xyz) You can drive longer without heating issue or autohold cutt off at 100 kmphr without fan
So guys if you having heating issue you need to lube both the belt as Ather may say maintenance free belt and all but it make big impact on performance so it will be making impact on range also Regular maintanence will give more range , more performance Especially in rainy season belt get dry fast hence degrade performance and range
/It works all the time /
Most of the belt noise ,range issue, performance issue is caused by a dry belt
Lube the belt properly
These are my observations after driving 10 k kilometer in my apex ![]()
No Wonder they did this bro
80-100 will take much time than Below that
Better Hide Your Indentify ![]()
Thatās Crazy Bro
Where do you from?
Itās just 10000 km small number
No actually itās does heat as before idk how Because I use the same route while travelling So I know how when apex Heat at what distance and all,so.normallly at full throttle at 100 kmph there is a point where I note vechile autohold will cutt off but after lube their is a shift in the distance till the cut of ,in same driving aspect so I told
My Ather 450 gen 3 rear suspension is gone. May I know the price of it?
2.5k INR But Part may not be available
Inform SC before Visiting to Change atleast a week or 10 Days
Which brand of lubricant are you using? Or are you just using grease? Iāve heard grease tends to attract more dust and debris. I havenāt applied anything yet,just regular service- my odometer is at 15k. Since the belt is fully covered in the Rizta, itās a bit of a task to access it.
you can ONLY use sillicon based lubricant sprays nothing else
As usual they delivered half cooked software. Accessing scheduled service returns āsomething went wrongā and the service history is unavailable for more than 3 months
Weird. I am able to service history. I am on updated IOS beta app.
11.4.0 Is this the one ?
@smridhi.kalati has confirmed that there is an issue and will be fixed soon. But new update is getting released without fixing the bugs and introduced new features
Am on ios 26 is it why I canāt join thru test flight!
Ahaan. That could be possible reason. I am not sure if they started testing for IOS26 yet. I have IOS26 on my secondary device. I will also try on it and let you know.
I am able to install beta Ather app on my secondary iPhone with IOS 26. (Developer beta)
I am sending you Ather TestFlight link via DM here. See if it works for you.
Yup worked just fine thanks sir ![]()
Awesome. Glad I could help.
is there a tyre hugger that fits the 450? Iām very much tired of having to wash my scooter daily also people behind me complain that the water from my tyres hit them thatās how bad the mud guards are the front one throws water all the way onto the headlights as well
