172 kms in a Single Charge with My Rizta 3.7 HR
Hi friends
Just wanted to share my Range Test Experience with My Rizta 3.7 HR
I have a 450 plus(3.5 Year Old) and Rizta is my second vehicle from Ather. Since I was curious to find the Actual range of Rizta I decided to take my Rizta for a range test at ODO 1328.
As planned started the vehicle at 3pm on 27.10.2024 with 100% SOC. My vehicle showed 100kms True Range in Zip mode and 125kms in Smart Eco
I preferred to ride in zip mode with an average Speed of 45kms/hr
The ride was very comfortable and butter smooth.
At 50% SOC I completed 90.3kms. The Time was 5.57pm
It was just testing my Patience.
At 8.37pm the Battery SOC went 0% and I felt happy that I had covered 172kms in a single charge. Time Taken 5 hours and 37 minutes. Closing ODO 1500
I am happy to Beat Riztas IDC Range of 159kms .
Surprisingly the next day , the ride statistics was missing for the date 27.10.2024 I raised a ticket with Customer care but they were unable to retrieve the lost ride data.
Ather should concentrate more on software to avoid bugs . Till now my ride is a Ghost ride….Unable to locate ….Only the pics taken by me during ride is left.
My Ride Summary is as follows
Vehicle Rizta Z 3.7 HR Starting ODO 1328 Closing ODO 1500 Kms driven in a single charge 172 Time Taken 5 Hours 37 minutes Date 27.10.2024
A proud Fan of Ather
Shelton
#Rizta unlocked
That’s my Brother :smile: Sheldon
Still can’t get my 175.2 KMs
175.2 KMs on a Single Charge and 1 KM + 2% SoC Left on my Gen 3 450x ⚡
Come on Bro, You can do this :muscle::blush:
Not to beat records. Just out of curiosity did a range test.
You are always my inspiration for long rides bro.I still remember the Goa ride, first in an EV with a portable charger from Coimbatore…
You are literally Amazing
I know, But I want you to do 190+ Bro
Thats why i triggering you :grin:
Nowadays I can’t drive below 50 kph :sweat_smile:
Thanks for giving Reminders Brother :slightly_smiling_face:
Bro, I am in Chennai, i use my rizta as daily drive for office, no matter how conservatively i drive, i can’t get above 85-95 on full charge. Is there any way to drive to achieve this. I drive mostly on Main roads always on ZIP mode, usually single, rarely my son will come along. Let me know if there is anything i need to know before going for long drives like yours. i once went for 100+ km ride with my son, had to charge the vehicle midway.
Is it LR or HR Bro?
The range depends upon the Riding style
Give throttle very slowly and then gradually increase the speed. Cruise at 40kms speed in Zip mode.Try this trick,you will surely see the difference.
Also too much of braking reduces the range. Use Magic Twist for regen. STRICTLY NOTE THAT MAGIC TWIST IS NOT AN ALTERNATIVE FOR BRAKING
Let me know the results after practicing these
Have a Joyful Ride
Like he said, only accelerate GENTLY.
Dont use more than 20-30% of the throttle.
And coast as much as you can. Meaning don’t accelerate or decelerate, as much as possible.
Using brakes = momentum energy transferred into heat energy which gets wasted (applies for Magic Twist as well)
To coast with coasting regen on, just hold your throttle at 4-5%.
Keep a good amount of space empty in front of you, and use it to accelerate and decelerate gently, like a cushion. If people are overtaking you, let them. It’s a good thing as people in rush will get ahead and stop honking at you.
Also helps with brake pads life. My rear brake pads still had 10-15% left at 10,000km service.
Hi
It is 3.7 Variant, so i believe it is HR.
Hi
Thanks for the Info.
I dont think it is possible to drive like that in Chennai traffic (peak hours), will try this on some Long drives, May be ECR road or Ring road. Another question Does pillion weight affects range? Physics says it should. but may be IDC is tested with Full load?
Thanks bro,
In your 170 kms drive, where you started and where you finished?
I am close to porur bro. So I was roaming in the Porur- Redhills Byepass road
Yes of course. The more you carry, the less range you will get. Also IDC is not tested with full load. They conduct the test with minimum load riding at a constant speed
@ smridhi.kalati Can the Software team help me in retrieving the data? Anyone to be contacted?
Yeah Its HR Bro,
Rider Weight and Payload also changes the Range Bro
How do i tell you bro
Great, i am in kolapakkam. Near porur
True… i usually get more range in zip even riding at 60km/hr as u said gentle and slow with throttle. I covered 33kms with just 25% consumed in Zip mode
I am facing the sane issue since the past update. This usually happens with shorter rides (<1km) but I observed a 20km ride to be missing from the stats
If Yours is Rizta then Rizta People facing this Issue
My 450x Gen 2 stats are perfectly syncing
Actually the problem is when the Display gets over heated , it blinks (restarts ) during ride. This is the reason for loosing data
