Changes i have seen after updating to 10.1.5
motor turns off when we engage the kick stand
repeated “450x “ animation screen seen while starting the scooter ( 2-3 loops) but vehicle can be used as usual .
ok got this update, happy to update that my dash board hasn’t restarted (yet !!!) and the Maps also seems to be stable and strangely its rerouting also correctly, the side stand also seems to be working… i rode almost 50-55 approx today…
Auto indicators working fine
Yesterday i was coming back to my home from a location and turned on the maps to see navigation; guess what damn maps didnt open up untill i reach the destination.
10.1.5 didn’t mean to fix any issues with maps/navigation. It was addressed to fix frequent dashboard restarts. I confirm that the dashboard restarts have come down. Once per day for me. Still high but lets me ride peacefully (mostly)
NEXT, 10.1.6, please @abhishek.balaji we are hoping, navigation issues/bugs will be addressed.
Still waiting for update
1 motor turn on sound not audible 2. Maps not working 3. Indictor sound not audible
Please look on this @abhishek.balaji
Today dashboard was very laggy, when you turn on the key 450x screen appears longer than usual to get ui, with repeated restarts
When you turn on / off side indicator more delay to engage to get sound/ light
When you apply side stand motor to off longer than usual
When you turn off the key dashboard gets off too late
The idle battery dissipation has increased for me. It goes down from 100% to 96% in less than 12 hours on bike being let idle.
Not sure if that happened after the latest update but I realised this after the update.
I have noticed this as well and it’s really pissing off. Not only do I see a lag in the time it takes for the indicator to start, I see a intermittent stop in the indicator for about 2 seconds. This is quite maddening at times.
I am yet to get this update on my Ather450X Series1……
Does any one have this?
I also have some problems after 10.1.5 update, while riding about same speed 35+ km/hr some strange noise come from dash board (mostly from cooling fan), it will not stoping after stop riding, fan still work for around 30s but noise is high.
Thats as per design. The fan kicks in at higher speeds and sometimes quite aggressively. We have recommended that the fan should kick only and only when the temperature of the dashboard rises to or higher than a certain degree. It should not be based on the speed. Let’s see if that gets implemented.
Ya it was like android software vs linux,
Linux very fast but creating apps challenging
Android you can do anything easily but lot of bugs
Its normal I think, now a days I will charge to max of 85 Ride upto 25/30 percentage
Rarely it may upto 100 percentage if longer rides
Same problem I’m also facing
Still dash reboots. Not exiting from charging screen,
I too agree with this , The battery drain is was sorted with the udpate before the 10.1.5 where the Sports mode lag was fixed and the battery dissipation was sorted , but with the 10.1.5 the battery dissipation has gone too high and the Range also is also very less , the Dissipation is such thatt for every 0.2 or 0.3 km the range goes decreasing by 1 Km under ECO mode , the true Range of 85 km under ECO mode isnt been a reality .
It is normal condition at higher SOC
No changes in the modes or the idle battery drain, can you share some ride stats or check the efficiency of some rides?
After this update I too facing the frequent dashboard restarent and some time if I turn on screen white screen comes. The cooling fan is frusturating. Once I on the key the fan will start.
Any one facing the same issue…
