This response might answer your query on why CCS2 is not feasible for 2W:
Thank you rajkumarā¦ But there should be some way to fast charge our scootersā¦ Because Ather grid will not be present at all locationsā¦ @atherenergy1 need to find some solution to this
Thank you sirā¦
But not ever location has Ather grid people are looking of long drives or on emergency fast chargers are requiredā¦ Ather need to look into this
Thank you sirā¦
BESCOM is 100 times less reliable than Ather itself. Their grid points are almost always turned off or they just donāt work. Even in BBMP HQ the charge point doesnāt work and other vehicles block you from access to it. It would be much easier for Ather to set up their own grid points than partner with BESCOM
The idea is okay but imagine what would happen if those who charge forgets to close the flap (given how responsible most are, majority will not close the flap) and it rains. It can be a serious hazard, right?
Moreover, we wont even get a 10km range in 30 minutes of charge right?
I donāt think soā¦ There are people charging cars or scooter every day in BESCOM. I spoke to mutli peopleā¦ Currently, only Ather scooter can be faster charged from Ather grid. But TVS scooter can be charged from BESCOM, means fast charge not slow chargeā¦ Apart from that, Revos Bolt is providing peer to peer charging network in Bengaluruā¦ Where ever Ather grid is not there, Ather scooter can be slow charged from BESCOM or BOLTā¦
Then He contact Ather ustomer care to toll the scooter or charger the scooter before going outā¦
Lucky people. I have not seen a single BESCOM charging point that works in the places Iāve visited. My complaints fell on deaf ears.
Actually, the port is designed to drain out spashes of water. Also, Iāve noticed that the position of the port reduces the chance of rainwater actually entering into it.
Lolā¦ It is not working at ur placeā¦but most of BESCOM station are working in Bengaluruā¦ I know people who are chargingā¦
When I said this,
This is what I meant.
Thatās why I called them lucky people.
Pls try Banashankari, ISRO layout, Mysuru Road. People can charge their electric scooter with normal plug. if not BESCOM, try Revos Bolt which has multi points in Bengaluru. I see Kona, Tata cars are frequently charged in BESCOM station. Very less scooters. Ather doesnāt have common plug which is only used in home or office. Unless BESCOM people allow with normal plug then fine, which donāt measure current I guess.
Ather grid in Park view mall in ITPL, Bengaluru. Fast charging was not supportedā¦ I have charged scooter this Monday. From 6 to 10.30 pmā¦ it charged only 77%. Stopped charging after 77%ā¦ Ather Grid is not installed in free parking area.
I have received a Revos Bolt Charger. Will be installing it soon.
Does the tvs iqube support fast charging? Afaik, tvs is only planning to introduce fast charging in the next version and existing models will be updated
Bolt support only normal charging. But they have very big network of charging in bengaluru. Like BESCOMā¦
Ather grid at Khelo bat academy in hoskarhalli is not working, when I connected the charger, scooter is not getting charged but able to charge it from home
I think Revos has shut down. The Bolt charger is not working and nor is the App. Can anyone confirm this?
