Hi, does anyone know if the STATIQ Charging grid will charge the athers?
If you see a wall connector like this, then yes you can plug in your portable/DOT charger.
But it’ll obviously charge slower than Grid charging.
okay and the type 2 charger is the same as Ather’s charging port?
No it’s not. Ather’s charging connector is derived from Type 2 Mennekes connector but it’s way smaller and has a different pin layout. For example, Type 2 Mennekes does not have DC + and - pins, Ather’s connector does have these two.
In short, only the 16A wall connector will work and you’ll have to carry your portable/DOT charger with you.
