Anyone having issue with the mirror setup? My right mirror is perfect and viewability is as expected. Although the left mirror is not adjustable to have the full viewability of what’s behind. I’ve tried to adjust it but at most it points down to the road. Just wanted to know if this is only a problem at my end. @Ather.Team I guess some checks went missing before delivery?
On other note, I think I’m in love with the customer support from Ather. Brilliant folks. Had an issue with the charging port at home, gave a call 20 mins back and they are already sending someone in for a check. @Ather.Team A kudos the support team.
@samitbanerji, feeling bad not attending Ather 1st owner meet.
May I know what went wrong and caused accident. Have you taken any damage pic before handing over bike for repair.
I too face this issue. So thought of removing the mirror for good… as of now it is no use bcz right mirror is not stable enough to stand in one place it always rotates for 180 degree angle..
Till few days back ather owners were around 238 in Forum and today I’m finding 338. Joined lot in few days… I check to know how fast owners tag rising…
At the time of the delivery I got the same issue with the left mirror and they have changed it, Now I am facing the issue in right mirror. Mean while I noticed that if u rotate mirrors frequently it will become very loose and it will start rotating 180 degrees while ur driving. So it is best to remove the mirrors and keep at home. When there is No use of it🙂
@shreyas Hi Shreyas
Considering how few others have faced same issue with the mirror setup maybe they this can be included in the final QA before delivery?
Congratulations! So did you take it without subsidy?
And as far as their word of caution, it was goven to me as well. It was just that it wasn’t deep rooted in my head. Now it is
Initially it took me 3 days to adjust the left mirror to my comfort. Now it’s not a problem. In my case, I was trying to keep both mirrors symmetrical and I wasn’t able to view anything. Now when I’m able to view properly, I see that that the left mirror is more vertical than the right.
A person driving on the wrong side of the road rammed into my 450 at right angles when I was leaving the parking lot of my apartment and getting onto the main road.
I have a general question, especially with the rains coming up:
What are the precautions we can take should roads/basement parking get flooded? I’ve started making it a habit to close the charging flap before heading anywhere afraid that the rain would go into the charging ports. I’m also finding that the lining between the seat and the storage is not completely water tight, and found a few drops of water when I opened it after rains.
Anything else? Has the vehicle been partially/fully submerged? Anything that should absolutely not get wet?
